Help! pls Water out tail Pipe. :(
Re: Help! pls Water out tail Pipe. :(
So i did a tune-up today the basic oil and plugs, my car has been somkin , well looks like white somke/vapor. an i checked the radiator just for lol and no water, so i put freez in toped it off with the green stuff, started the car smooth running , i go to check if my tail end is still somkin cuz i thought it was the turbo going bad, and there is a stream of water coming out, i rev it up and more comes out . WHAT is This pls help.
thanks. in advance.
P.S my car dos not overheat , when i checked the other day to see if water was still in it i was and no oil in water, but when the water runs out there is a small amount of brown gunk on the cap.
p.s 2 i just been using water this is the first time i put freez back in. since tuneing it up.
thank again
thanks. in advance.
thank again
If your car is running fine, idk why you're trippin.
Moisture gets built up through your exhaust over time. It's normal IMO.
Are you losing coolant? If so, your head gasket might be busted.
If not, it could just be condensation from the cold weather.
I mean, when you say stream of water, how much water are you talking about??
it looks like the ac is runing out the tail, i have lost water alot but i kepp puting water in no freez, and even with no water in , it still runs normal. and another thing when i was changing the oil and filter i looked at the head gasket from under, and on the exhaust side i could see like gunk build up on the edge of the gasket like ifs its really small leak under alot of pressure and its building up link a bad valuve cover gasket, but yea it runs rine , but when i hit high boost or full throttel it feels like it missis or backfires and then drops psi. but in 1,2, and stuff under 45mph it runs hard, idk the car is wierd. purrrsss thow
sounds like you have a blown head gasket. sounds like the white smoke is your car burning water and coolant
smoke = blown head gasket
it looks like oil in the frezz when on the cap when i check but very little.
so cometic gasket with arp studs and a rebuilt head would fit my build aswome
i use 50/50 but i was using water cuz i never bought the freez i was lazy
the headgasket is blown for sure, so rebuilt head, new hg and head studs will be needed since you are boosted. i use 100% antifreeze.
Find someone with a block tester and have them check your car for you,that will tell if you have combustion gasses in the cooling system.
no my turbo is oil only and i was told not to use only fezz that it can brake the block internals. and or blow the head gasket again.
im just going to swap the gasket any ways no hurt in a new gasket and studs.
i do boost the car alot
