1999 Honda Accord V6 .. I cannot trace leak! Pls help
Old Apr 17, 2016 | 10:33 AM
Eddie92gt's Avatar
Default 1999 Honda Accord V6 .. I cannot trace leak! Pls help
So for a while I've had a big leak to were it started to get all over the belts ( had to get new belts because they ripped) I assumed it was going to be the crankshaft seal so I installed new timing belt and crank seal . I also noticed the top left by the cam shaft cover there is a leak as well . I did check the the cam seals and no signs of leaks .
So I put it all together , and still it leaks around the bottom area of the crank ... It looks like at high Rpms it leaks out more ( I'm assuming )
I just replaced it for 2nd time thinking maybe I shouldn't have put oil around the inner seal so this time I put it in dry just a slight bit of mechanical grease on the inner part ... And still same leak ... ( I replaced the oil filter gasket as well that attaches to the block .
Questions : Can a lower head gasket leak oil ? The car has never ran hot though and I checked the rear valve cover gasket with a mirror and no signs of leak .
Should I purchase the UV dye to trace the leak? Where else can it be leaking out of ?
Thanks guys .. I'll post pictures in a bit ... Ed
Top left near firewall by cam
Top left by fire wall cam cover leak
u118224
Jul 23, 2014 07:10 PM
MacR6
Jan 2, 2014 09:35 PM
blurry454
Jul 28, 2009 09:29 AM
CO_CReX
Jan 30, 2006 06:59 PM
Neukin
Mar 9, 2003 02:59 PM
