Vss sensor install in 90 crx si
Old Apr 16, 2016 | 11:20 AM
Brandon Stump's Avatar
Default Vss sensor install in 90 crx si
I got my sir cluster wired in and working fine. Now just need to wire vss in.. I got the 97 manual vss because it fits better than the 92-95 car trans is a d16 at the moment l my question is can I run the 3 wires to the back of the cluster I know one is ground signal and power for the signal I was thinking about running it off the vss wire that is not used the ground to any ground. And the power to a power wire. Any suggestions ?
Old Apr 16, 2016 | 01:30 PM
v4lu3s's Avatar
RTFM
Default Re: Vss sensor install in 90 crx si
I can't make sense of what you have and need. Are you using an obd0 cluster? Or obd1? If 0 you need to run the cable from trans to cluster and get vss signal there. If you are using an obd1 cluster and you will probably do best consulting a wiring diagram to emulate stock wiring as best possible.
Old Apr 16, 2016 | 01:49 PM
I figured it out thanks anyway
french_yogi
Apr 18, 2011 06:24 PM
michael O
91
Apr 18, 2011 08:04 AM
jacksonww
May 4, 2009 10:41 PM
USDMSiR
15
Aug 31, 2006 02:07 PM
All_Motor EF9
Jan 4, 2004 05:29 PM
