Do 98 civic dx have stock sway bars??
Old Nov 7, 2002 | 07:57 AM
vtec69's Avatar
Default Do 98 civic dx have stock sway bars??
Just wondering if my 98 civic coupe dx had a stock sway bar?
Also if so how big is it?
Also would a sway bar form a 2000 gs-r fit my car?
and what would i need to make it fit?
Thanks
-Brian
Old Nov 7, 2002 | 08:21 AM
brcivic411's Avatar
Default Re: Do 98 civic dx have stock sway bars?? (vtec69)
nope, don't got one. not sure what it would take to make a gsr one fit either
Old Nov 7, 2002 | 08:24 AM
isotopesope's Avatar
Default Re: Do 98 civic dx have stock sway bars?? (brcivic411)
which sway are you concerned with? front or rear? the rear will bolt on with all of the neccessary parts: si end links, d brackets, bar, etc. beaks products sells a kit with everything you need. for the front sway you need to get ex/si front lower control arms that have the mounting holes for the swaybar.
Old Nov 7, 2002 | 08:26 AM
cre18's Avatar
Thanks
-Brian
no stock front or rear sway bar for the DX. you can add a rear 22mm itr sway bar with reinforced subframe plates and si endlinks using the beaks kit. great setup
Old Nov 7, 2002 | 08:33 AM
vtec69's Avatar
Default Re: Do 98 civic dx have stock sway bars?? (cre18)
cool thanks guys
Old Nov 8, 2002 | 12:54 AM
EddieHatchBlack's Avatar
Don't forget for DXs since it has NOTHING, you should add front and rear at the same time.
91EF919
Sep 1, 2008 07:50 AM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
RedGSR
Jun 10, 2004 01:57 PM
DreamSpeed
14
Oct 25, 2001 09:57 AM
