PCV hose cap on intake
Old Apr 15, 2016 | 05:40 PM
Captncrusade's Avatar
Default PCV hose cap on intake
I have a breather on the valve cover of my turbocharged d16z6. The short ram intake has the little nub on it for where the hose for the pcv valve is supposed to go. i didn't want that sucking unfiltered air into the turbo so i capped it with a rubber vacuum cap for now. but that rubber is quickly dry rotting or something. the heat is making it crack and im afraid its going to crumble and get sucked into the intake...which would be bad. is there anything better to cap this with? another air breather maybe? ...and don't say catch can. no catch can.
Old Apr 16, 2016 | 06:26 AM
bcintron95's Avatar
Default Re: PCV hose cap on intake
Doesn't need a breather. I would get a higher temp hose cap if it's that bad.
Old Apr 16, 2016 | 06:27 AM
Sprockets's Avatar
Use a silicone instead of rubber cap or weld it shut.
Old Apr 16, 2016 | 01:22 PM
2kdrift's Avatar
I would recommend running a vaccum hose between the two
Old Apr 16, 2016 | 04:18 PM
But that would take all that blow-by and spit it into the turbo which would then turn my intercooler into a glorified oil separator
Old Apr 16, 2016 | 05:59 PM
2kdrift's Avatar
Its a known method of relieving crankcase pressure recommended by numerous veterans on here
Wazup
Jun 28, 2019 09:33 AM
ghostlude99
Oct 12, 2008 10:09 AM
madcrossover
Sep 16, 2004 11:35 AM
Rick
Sep 27, 2003 05:33 AM
zyntax
30
Aug 7, 2003 07:35 PM
