96 gsr cel will not turn on!!
Old Apr 15, 2016 | 04:34 AM
teggyluva90's Avatar
Icon5 96 gsr cel will not turn on!!
Hello my fellow integra fams. My check engine light in my 96 gsr won't turn on even at the key at ignition when all lights should turn on. Yes the bulb is there in my cluster the connector that plugs to the cluster found the diagram for it in the 13 pin plug an it's pinned where it should be. So IDK what's going on also my p28 is good had it bench tested by my tuner because I'm running ectune in it I even put back my stock obd2a p72 ecu an still no light just my MIL(maintenance required light) flashs like it should then turns off when I turn her on. My tuner said my cel should flash 3 times when I turn on my gsr because of ectune. Tried to find the little blue plug on my passenger side an can't find it to jump it an I think the previous shitty owner cut it off. Just itso you guys know.
Old Apr 15, 2016 | 08:40 AM
fcm's Avatar
fcm
Old Fart
Default Re: 96 gsr cel will not turn on!!
Have you checked the bulb itself? 94
Old Apr 15, 2016 | 01:38 PM
It has new bulbs the whole cluster and sockets dude.
Old Apr 15, 2016 | 08:34 PM
Nothing
Old Apr 16, 2016 | 07:25 AM
fcm's Avatar
fcm
Old Fart
Do you have power at fuse 25 with ign. on?
Do you have a ground at ECU A18, [green/orange]?
If both, good check continuity of green/orange between ECU and cluster plug, dude. 94
Old Apr 17, 2016 | 05:43 AM
Where is fuse 25 located at?. Under dash box right? An what port is it. I'm going to check the ground for the ecu A18 right now thank you .
Old Apr 17, 2016 | 06:53 AM
fcm's Avatar
fcm
Old Fart
Sorry it is fuse 15-10A, in under dash fuse box, numbers are on the fuse box itself. 94
Old Apr 17, 2016 | 09:51 AM
All good bud you doing me a solid. Okay thanks and took photos of these cut wires coming out of connector A.
And yep a18 cut as you see the green/orange.
a disaster dude but simple lol
Old Apr 17, 2016 | 04:19 PM
Also this cheap step down harness doesn't even have mil wired up the pin isn't there so even if I wired back up the green/orange wire for The cel dude it wouldn't turn on because of the step down harness as you see right here. So hello order rywire step down.
Thank you man
Old Apr 19, 2016 | 01:51 PM
fcm's Avatar
fcm
Old Fart
Ugly, that got hot, looks like pin 13A, green/orange is MIL on the P28,, same color diff. location, make sure the jumper is wired correctly so pin 18A of cars harness, [cut lead] jumps to pin 13A of the p28. 94
Old Apr 20, 2016 | 07:32 AM
What got hot?.Okay just looked up the diagram for p28 ecu pins. A13 is the cel you right green/orange. The jumper harness I followed A18 to see if it go to A13 and it does so going to solder back the A18 wire from my cabin harness, the previous douchebag cut it man but thank you sir let me do what you said an see.
Old Apr 20, 2016 | 01:49 PM
And that cut green/yellow wire you see is from A8 the integras VTS or vtec solenoid so the previous owner had it running straight two wires to use a obd1 ecu cause it had a ls engine harness which I got a uncut LA engine harness because the one it had on was merked smh. Also I have a jdm block no knock sensor . I'm going to find a good uncut obd2a gsr engine harness.
Old Apr 21, 2016 | 07:40 AM
fcm's Avatar
fcm
Old Fart
What got hot? never mind, it just looks burnt, but it is just the plastic that is "discolored" 94
cisco_kid
Jun 22, 2015 06:45 PM
Honda904
Feb 19, 2014 11:14 AM
xNRxJose
Apr 7, 2008 01:23 PM
CHAMPwhteEK
Mar 25, 2007 02:49 PM
EkREV
Sep 19, 2005 09:01 PM
