Slow moving fuel gauge & low fuel light issue.
Old Apr 14, 2016 | 11:37 AM
Ohmega's Avatar
Default Slow moving fuel gauge & low fuel light issue.
1996 del Sol SI
Stock D16Y8
Searched. https://honda-tech.com/honda-civic-d...-slow-2488076/
No solution posted.
Fuel light does not turn on when at the red line for empty. After refueling, the gauge takes approx 1 1/2 minutes to reach the full mark.
Going to be changing out my fuel pump this weekend and i wanted to know if there was a quick fix that i can do whilst in there.
Old Apr 14, 2016 | 12:03 PM
halfdemonpyro's Avatar
Default Re: Slow moving fuel gauge & low fuel light issue.
Normal. The gauge has a resistance to movement so that as you drive its not bouncing around everywhere from fuel sloshing around.
Old Apr 14, 2016 | 12:48 PM
Ohmega's Avatar
Thanks for the reply.
Sounds plausible Never heard of that before, though.
Any thoughts on the low fuel indicator lamp? Any way to test the bulb without removing the cluster?
Old Apr 14, 2016 | 01:02 PM
SohailB16's Avatar
DIY [EK] : How to check is the low fuel light working or not
Old Apr 14, 2016 | 03:24 PM
Ohmega's Avatar
Thanks for the link.
That requires me to rip apart my interior to get to the service lid. Since im installing a new walbro 255lph ill do it then.
Old Apr 15, 2016 | 12:12 PM
ForrestGump's Avatar
Fuel cleaner
Old Apr 15, 2016 | 01:45 PM
The civic actually has a fairly fast moving gauge for an OEM car. My focus never twitches at all, where the civic will change if you are going up or down hill for any length of time.
Old Apr 15, 2016 | 07:06 PM
jonsey1886's Avatar
10 Year Member
Simpler how-to is linked in my sig including removal of rear seats.
Old Apr 15, 2016 | 08:22 PM
tony_2018's Avatar
Fish Twig
Same thing, still have to remove the rear seat to get to the fuel pump....
Old Apr 17, 2016 | 04:20 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Hardly "rip apart" the interior .... lift up rear seat, 4 screws on the panel. Honda made it easy!
Old Apr 18, 2016 | 09:51 AM
tony_2018's Avatar
Fish Twig
Right?
Old Apr 18, 2016 | 10:56 AM
Ohmega's Avatar
So this weekend I began the installation of my turbo system.
2 days, a few banged knuckles, and a whole slew of curse words later, the turbo is in and all that is left to complete the setup is wiring in an injector resistor box.
The fuel gauge problem doesn't bother me enough to look into it, i was just curious as to what caused it. Upon removal of the fuel pump apparatus, i discovered an exposed wire. I must've snagged it on the fuel tank lip when removing it. I knew electrical tape would be eaten by the gasoline, so i opted to try and liquid-proof it instead with honda-bond. This was a last ditch effort because i had my dad and friend stumped on how to fix it. anyone see any potential problems with this fix?
Edit: The del Sol interior isn't as bad as i thought! Took me about 25 minutes to take out the necessary trim pieces, and remove the fuel pump apparatus.
Old Apr 19, 2016 | 10:29 AM
Nave43's Avatar
Lol at people saying to remove the back seats
93 del sols weren't wired to have a fuel light, your 96 should be though. Possibly just a bad bulb (cluster comes out hella easy, type 74 bulbs). If not the bulb ide blame the sensor near the fuel pump or a cut/ shorted wire
Also i would solder in a wire on the fuel pump end and splice it together away from the gasoline. Put some cured honda bond in a jar of gasoline and see what happens if your curious.
Old Jul 22, 2016 | 07:09 AM
Ohmega's Avatar
Update: I removed the fuel pump with the Honda bond on it. Turns out Honda bond turns to rubber when submerged in gasoline. When I removed the pump apparatus, the Honda bond was so swollen it was loosely hanging around the wire. Here's a pic. Hondabond fail. The cut wire is visible here as well.
Old Jul 22, 2016 | 08:55 AM
deschlong's Avatar
Loved
Community Favorite
What about liquid electrical tape? Dunno. Check if it has problems with petrol also.
Kogdevilnuts
Feb 15, 2015 02:55 AM
mois93da
May 13, 2014 05:03 AM
CanadianES1
Apr 9, 2010 06:39 PM
blksnkk
Mar 5, 2007 07:29 PM
mrdeadman
Sep 2, 2005 01:25 PM
