CTR Piston
Watchu guys think about putting them CTR piston http://www.ebay.com/itm/JDM-HONDA-CI...VRVc~B&vxp=mtr
into a PR3-1 bottom and a PR3-3 head? Performance and quality wise are they any good?
For the best performance of your engine,always start with a straight bore cylinder,Since your used cylinder is already 81mm you will give some perfection away.
You can at least check your cylinder if they are out of round first.If i was you id go straight to the oversized piston from your link.
