Valve Spring for CTR cams in a B16
Old Nov 7, 2002 | 07:23 AM
Squalo's Avatar
Default Valve Spring for CTR cams in a B16
Are CTR valve springs the best for CTR cams in a B16A2 if I want to be able to rev to 8500. I have been told that the stock B16A2 intake springs are the same as the CTR exhaust springs anyone know if this is true. I already have SS valves and I will also be using Ti retainers. Also need CTR intake valve spring part #s inner and outer if anyone has them.
Thanks
Old Nov 7, 2002 | 07:26 AM
fowler!'s Avatar
Default Re: Valve Spring for CTR cams in a B16 (Squalo)
If you've spent that much money on valves and retainers, why don't you go the extra step and gt some good springs.. Crower, JUN, Portflow would all be better than stock CTR.
If you ever decide to get some better cams, you'll be bitter that you have to go in there again and take them out.
Old Nov 7, 2002 | 08:38 AM
Hunter's Avatar
Default Re: Valve Spring for CTR cams in a B16 (fowler)
i'm runnin' ITR springs w/ my CTR cams
Old Nov 7, 2002 | 09:01 AM
EGsixer's Avatar
Default Re: Valve Spring for CTR cams in a B16 (Hunter)
is it ok to run CTR cams in a stock b16a2 head? i have been it is..is that true?
Old Nov 7, 2002 | 09:52 AM
fowler!'s Avatar
Default Re: Valve Spring for CTR cams in a B16 (EGsixer)
Yeah, not a problem at all.
Old Nov 7, 2002 | 09:59 AM
thinkbrianthink bu's Avatar
word to the unwise...
if you run TOO stiff of a spring you will lose power.
you'd probably be ok running the stock valvetrain but if i were you id go with an easily accessible and not too expensive itr valvetrain.
Old Nov 7, 2002 | 10:04 AM
SIReg9's Avatar
Default Re: Valve Spring for CTR cams in a B16 (thinkbrianthink)
Do yall think Skunk2 valve springs are too stiff for Crower stage 1's? The stage 1's are suposedly CTR+, i think they have a lil longer duration.
Old Nov 7, 2002 | 10:06 AM
ill phil's Avatar
Default Re: Valve Spring for CTR cams in a B16 (SIReg9)
Stock valvatrain should be fine as long as you keep the same redline and rev limiter
[Modified by ill phil, 1:06 PM 11/7/2002]
Old Nov 7, 2002 | 10:07 AM
if there is a small difference in the cams im sure it wont hurt but from my experience it isnt a good idea to run jun springs with ctr cams.
Old Nov 7, 2002 | 10:25 AM
SIReg9's Avatar
I am running them on stock springs now, But im about to do a full buil don my motor and i just got my ECU chipped w/ a 9600 rev limiter, and i already have the Skunk2 springs
Old Nov 7, 2002 | 10:28 AM
Hooch'n's Avatar
CTR's in B16=
Old Nov 7, 2002 | 11:29 AM
qtiger's Avatar
Why don't you get Skunk2 stage 1s instead of those Crowers? For a little more cash you'll have a lot more power, especially on a b16.
Old Nov 7, 2002 | 11:38 AM
Squalo's Avatar
I want to go with the CTR springs because there made for the CTR cams, the SS valve I have are just a hair lighter than CTR valves, but don't know if there is anthing better but not with stronger spring rates. As for the cams the motor is Vortech supercharged and there isn't a cam out there I've seen that out performs the Honda cams across the board, there are cams that make more top end but loose to much bottom end and midrange this is a daily driver. Does any one have the CTR springs part #s or know where I can get the springs
Old Nov 7, 2002 | 12:57 PM
SIReg9's Avatar
I got the Crower cams at a good price, and skunk2 valve springs were the only one sthey had in stock. I am gonan be running my b16 head on a GSR bottom end with my b16 pistons in there.
coolzone670
Sep 28, 2011 10:11 AM
Dc2 Joe
166
Jul 4, 2005 11:25 AM
sal_blkej2
Mar 23, 2004 03:19 PM
Dammit_Dan_954
Nov 22, 2003 12:27 PM
klnteg
19
Nov 18, 2003 01:48 PM
