B18b gas on top of piston
Old Apr 12, 2016 | 10:34 AM
Blessed Chico's Avatar
Default B18b gas on top of piston
Hey guys, I just got my car tune and my aem wide band seems to be running to rich, it's jumps from 13.5 to 10.00 and sometimes lean, so I checked I took my spark plugs out and there seems to be gas sitting on top of my Pistons, does anybody know why is doing that? By the way the motor is a b18b on boost, injector size 750. Any ideas what it could be?
Old Apr 12, 2016 | 10:43 AM
oldschoolmaster's Avatar
Default Re: B18b gas on top of piston
It's a tunning issue should be around 14.7 on idle 12.0 on full throttle
Probably with a coil on distributor messing up if no codes and fuel map is correct
Old Apr 12, 2016 | 10:45 AM
It's a brand new distributor and yeah it just jumps around, and by the way it's tuned on a hondata s300. So is it bad having the gas there?
Old Apr 12, 2016 | 11:00 AM
Check your timing and yes its bad it can damage the rings
Just because new doesn't mean it's good
Old Apr 12, 2016 | 11:06 AM
Damn yeah I don't want that to happen and okay I'll check it as soon as I get home, by the way when I step on the pedal to 3k rpm the the check engine light lights up?
Old Apr 12, 2016 | 11:11 AM
motoxxxman's Avatar
that should have been the very first thing you said. that right there will cause all of the issues you're finding.
check the code, fix whatever the code says.
done.
Old Apr 12, 2016 | 11:15 AM
done.
Okay I'll check that today and let y'all know what i find on the codes, but it only does it when I step on the gas, it'll hesitate a little to 2 step and then it starts 2 stepping but I'll check the codes and timing belt and see what I find.
Old Apr 12, 2016 | 11:22 AM
[QUOTE=Blessed Chico;50859699]Okay I'll check that today and let y'all know what i find on the codes, but it only does it when I step on the gas, it'll hesitate a little to 2 step and then it starts 2 stepping, and when I'm driving it and I pass 3k rpm the check engine lights pops up and my aem wide band reads 10.00 and when I step on it hard it shoots up to 17.00 so I let go of the gas and barely push on the gas it just sits on 10.00, so I have to turn it off then back on and it's back to normal till I rev it past 3k again
Old Apr 25, 2016 | 05:16 AM
Okay so I haven't checked the check engine light, but I did hear some loud scratching noise coming for the distributor, n when I put the key on, on not fully turn it on, the fuel pressure gauge goes to 40psi then shoots back down to 0, and Also you can hear like a loud hiss from the fuel rail? N I also bored bought a new distributor n still hear the loud scratching?
Old Apr 25, 2016 | 05:31 AM
Blessed Chico
Engine Management and Tuning
May 5, 2016 07:12 AM
jdmshawn95
Jan 20, 2012 12:44 AM
OoAoO
May 11, 2011 11:20 AM
racingcrx
31
Nov 7, 2010 06:59 PM
xxnickpxx
Apr 8, 2007 04:13 PM
