Failed emissions.
Old Apr 10, 2016 | 03:13 PM
Granulatedsugar's Avatar
Default Failed emissions.
Took my crx in to get safter and emissions in and it failed horribly. For hc the max I can have I'd 220 and my crx had 608. For the co the max I can have is 1.2 and my crx had 5.4. I've never had a car fail emissions. Can somebody help me? I bought a new cat yesturday but I don't know if that would be enough to bring emissions down that much? The car is also getting poor gas mileage at around 28 mpg. I know the crx should be getting more around 40 or 45.
Old Apr 10, 2016 | 03:57 PM
ZC1.8crx's Avatar
Default Re: Failed emissions.
I don't know were you live, but in my state, any car over 25yrs old, does not need to be emissions tested any more.
Old Apr 10, 2016 | 04:00 PM
acmoc's Avatar
My first guess id o2 sensor
And tuneup
Drive around a while first, because the ecu needs to calibrate.
smog techs dont tell you this.
Likely you will faiil if you go back right away after a repair
Old Apr 10, 2016 | 04:07 PM
Former User's Avatar
Post the entire emissions sheet.
Old Apr 11, 2016 | 04:24 AM
Old Apr 11, 2016 | 04:34 AM
The very high O2 levels under both conditions indicate that an exhaust leak is causing the engine to run rich.
Old Apr 11, 2016 | 05:10 AM
Can an exhaust leak really cause high hc and co? I have a new muffler on there but theres a few small holes I temporarily patche'd with this metal tape I had. Is it not my cat or o2 sensor?
Old Apr 11, 2016 | 05:19 AM
Absolutely. Read about how your O2 sensor works.
An exhaust leak falsely tells the ECU that the engine is running lean, causing the ECU to compensate by increasing fuel to the cylinders.
Old Apr 11, 2016 | 05:25 AM
So this means I have an exhaust leak in my header or what? I mean I haven't found any holes above the cat but haven't checked the header yet. I know that if I were to have an exhaust leak above the o2 sensor then I'd have a problem but the o2 sensor is in the middle of the header
Old Apr 11, 2016 | 05:45 AM
Carefully check the header for cracks. Also check header gasket and the bung for the O2 sensor in the header.
Old Apr 11, 2016 | 05:49 AM
So if I find a crack or something, that'll fix my emissions problem?
Old Apr 11, 2016 | 05:51 AM
What you need to know is that an exhaust leak around the O2 sensor in the header WOULD cause the engine to run rich.
Old Apr 11, 2016 | 06:18 AM
whited's Avatar
CRX God
It could also be a bad injector or just need a tune up.
Old Apr 11, 2016 | 06:53 AM
Alright. Would a bad catalytic converter not be a problem? How would I know if its a bad injector?
Old Apr 11, 2016 | 06:54 AM
Don't ignore the incredibly high O2 levels. Any theory about the emissions problem must explain that.
Old Apr 11, 2016 | 07:00 AM
Ya I'm not sure it can be a bad injector because the engine doesn't misfire and runs really well. I will check the header for cracks or a bad gasket this afternoon. That would be why I have such high o2 correct?
Old Apr 11, 2016 | 07:01 AM
Exactly
That's the possibility you should focus on first.
Old Apr 11, 2016 | 07:05 AM
Alright thank you! The possibilities are a blown header gasket or a crack/hole in header?
Old Apr 11, 2016 | 07:08 AM
Old Apr 11, 2016 | 07:52 AM
I'll let you know what I find this afternoon
Old Apr 11, 2016 | 11:46 AM
If there was an exhaust leak somewhere around my header, wouldn't i hear it? It would be really loud wouldn't it?
Old Apr 11, 2016 | 01:13 PM
acmoc's Avatar
You would smell it.
I dont think it's an exhaust leak
These cars don't have filters for the cabin so you would know
Old Apr 11, 2016 | 01:19 PM
Did you inspect the header and its gasket?
It's the entry of air into the exhaust not the escape of exhaust into the air that causes the problem.
Read about the Venturi effect.
https://en.wikipedia.org/wiki/Venturi_effect
Old Apr 11, 2016 | 01:44 PM
acmoc's Avatar
Oh, well yea you should listen to Ron
That makes more sense.
Can a vacuum leak cause rich conditions?
Or is that lean?
Old Apr 11, 2016 | 02:19 PM
Could this crack between the manifold anddown pipe be the cause? It is about an inch under the o2 sensor. The other side has no crack at all<br/>
