which axles for hydro transmission
Old Apr 9, 2016 | 05:39 PM
cityofcaterpillars's Avatar
Default which axles for hydro transmission
I've been searching forever but cant find a straight answer. Will my stock axles (STD hatch) work with a 97 hydro transmission?
Thanks
Old Apr 9, 2016 | 09:30 PM
brixcivic's Avatar
Default Re: which axles for hydro transmission
dohc and sohc are different of course.. u gotta use the same axles and halfshaft. if u got a cable b16 motor and trans and then switch to hydro trans u use same axles and halfshaft. hope that helped
Old Apr 10, 2016 | 04:50 AM
sorry should've been more specific. I'm staying d series just swapping transsmissions.
Old Apr 10, 2016 | 09:31 PM
4drEF's Avatar
Keyboard Humorist
Stock axles will work
Old Apr 11, 2016 | 10:55 AM
whited's Avatar
CRX God
I agree.
The only difference between axles between a 92-99 civic ex and a 88-91 Si, is that the Si will have a thicker shaft, but the splines and shaft that goes into the transmission and hub are the same.
Old Apr 16, 2016 | 03:24 PM
duugle's Avatar
Originally Posted by whited
I agree.
Use the axles that match the transmission. The spline count will be the same for all D series except the 4 speed transmission, but the axle length is different between EF and EG/EK.
The 88-91 axles are different lengths than 92-95.
EG Left = 773mm-778mm
EG Right = 500mm-505mm
EF Left = 775mm-780mm
EF Right = 483mm-487mm
80 dolla crx hf
Sep 7, 2009 08:31 PM
lilsicsoul
Mar 18, 2009 04:56 AM
d16sandrail
Jan 21, 2009 01:52 PM
Shonda
Oct 18, 2006 07:57 AM
bluez6
Aug 27, 2006 12:49 PM
