Brake trouble
Old Apr 8, 2016 | 04:18 PM
Laurentius's Avatar
Default Brake trouble
My front brakes locked up one day. I changed the calipers, pads and lines. drove it to work on the way home they locked up again. I changed calipers and pads again. bled the system all around. drive it again for a few miles the front start locking again. what can be the problem?
Old Apr 8, 2016 | 04:20 PM
Laurentius's Avatar
Default Re: Brake trouble
it a 1990 Honda accord LX
Old Apr 8, 2016 | 06:31 PM
MAD_MIKE's Avatar
MM Gruppe B
Verify that the brake pedal is not dropping or the pushrod is not over adjusting and not allowing the MC to fully release.
System in these cars is diagonally split(not front/rear) it would be highly unlikely that divorced parts of the system would fail concurrently.
Verify the MC is in proper working order and recheck any work that has been recently done to the car.
Old Apr 8, 2016 | 07:23 PM
Laurentius's Avatar
I have a question. before all this trouble, I tried to get the car inspected the car was fine. the car failed inspector said I don't have no brake lights I need a brake switch. I took the car home notice that the brake light now stay on. i got down to the pedal and notice that there's a little plastic piece that makes contact with the switch was missing. it looks like it goes on the pedal and makes contact with the pin on the switch that makes the brake lights comes on and off with the pedal. so i got desperate and put a screw in its place. could it be that this screw is too thick and not allowing my pedal to work properly? if so what is that little piece called where can i get one. its a little piece look like it just push in the hole on the pedal.
Old Apr 8, 2016 | 07:34 PM
Laurentius's Avatar
although the brake lights on my car is working. If the screw is too thick . its the same if i was riding with the brake pedal pressed.
Old Apr 8, 2016 | 07:37 PM
MAD_MIKE's Avatar
MM Gruppe B
If your brake pedal is missing the pad then that is your problem.
The part is called a 'pad, pedal stopper'
Cost is ~$3 from the dealer.
Old Apr 8, 2016 | 07:45 PM
Laurentius's Avatar
Ok thanks I talked to guys about it I mention it they said no and had me change everything.
Old Apr 8, 2016 | 07:48 PM
Laurentius's Avatar
Is the dealer the only place to get one?
Old Apr 8, 2016 | 08:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Dealer or junkyard,
Old Apr 8, 2016 | 11:46 PM
djkurious's Avatar
Dorman part 74015. I went through the same thing as you with a customers car. Brakes kept smoking and found a screw by the brake switch.
Old Apr 9, 2016 | 05:11 AM
Laurentius's Avatar
Thanks alot i'm going to a local honda dealer today.
Old Apr 9, 2016 | 03:29 PM
holmesnmanny's Avatar
You can get that part from any parts store.
Old Apr 9, 2016 | 03:33 PM
Laurentius's Avatar
Thanks I got the part already and will put it on tommorrow. I'll give you all an update on what happen. Thanks again.
Old Apr 15, 2016 | 03:02 PM
Laurentius's Avatar
Thanks guys that did the trick.
justBrowsing
Honda Civic (2001 - 2005)
Jun 27, 2014 12:26 PM
baer13
Suspension & Brakes
Sep 15, 2013 03:16 AM
gqstatus05
Apr 11, 2011 05:39 PM
helpmeplease
Mar 24, 2008 03:37 PM
Vanadium
Mar 7, 2008 03:26 AM
