Bb6 prelude install issue.
Old Apr 2, 2016 | 09:11 PM
PunisherAccord's Avatar
Default Bb6 prelude install issue.
Anyone have input on this? So half of my cluster lights won't light up, I quadruple checked the wiring and the bulbs and there is no issues with them they go to their corresponding wires as for the bulbs they work found out when I put the bulbs on the right side that I thought weren't working on the left side where it is and they worked then I bought an extra prelude cluster and I got the same problem. Anyone run into the same issue?
Old Apr 2, 2016 | 10:43 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Bb6 prelude install issue.
Is this a Prelude cluster in an Accord?
In the second picture I can see part of your dash uncovered. I know on my '95 if the Hazard button is not plugged in the lighting is either wonky or not on at all. I would suggest you verify that all electrical connections are made before blaming the cluster.
Old Apr 2, 2016 | 10:58 PM
It is a prelude cluster in my accord. As I stated above the witing is NOT an issue I checked several times and the prelude pigtail wires are soldered into the corresponding accord wired also the bulbs are fine, the dimmer is good.
OmarR
Feb 24, 2008 07:59 AM
ef93si
Jan 29, 2006 06:29 PM
steronz
Feb 20, 2005 02:31 PM
