Trouble starting 2008 Honda Civic
Yesterday i got home with my civic and parked and went to leave 30 minutes to an hour later and it would not start , cranked fine , could hear the pump priming. I left it and came back a while later and it eventually started. Then this morning it started fine again but I did not drive it ,then by the afternoon it would not start again . I came back to it a while later and cranked it a few times and it eventually start again. Does anyone know what the problem could be ?
Of anti freeze under the passenger side of the engine.
It may be because your starter is starting to wear out. When you turn your key, an electromagnet forces the starter gear to engage the teeth on your fly wheel. The motion of the starter gear sliding forward into the fly wheel also engages electrical contacts which give power to the starter motor, spinning the starter gear and starting your engine.
ef9_pr0jekt
Mar 7, 2020 07:44 AM
Nassimab
30
May 27, 2016 10:08 AM
cast.aluminum
Nov 25, 2014 08:23 PM
