Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help!! 2000 civic d16 swap!
Old Apr 2, 2016 | 11:05 AM
StephanHalas's Avatar
Default Help!! 2000 civic d16 swap!
Hello, brand new to the site. I have a 2000 Civic LX. Originally a D16 Non Vtec. Motor spun a bearing so I bought a donor car, 2000 Civic EX, motor is a D16 Vtec. I swapped everything over, harness (never disconnected from motor or trans), ECU. Everything but the ABS. Car starts no problem, drives fine, shifts fine. But now, if I floor it, the car has a 5000rpm rev limiter and I have to back off the throttle to shift. Motor and trans did not have this issue before it was pulled. Please if you have any thoughts please send them my way! Much appreciated!
Old Apr 2, 2016 | 12:06 PM
DA9_LEO's Avatar
Default Re: Help!! 2000 civic d16 swap!
Do you have any Check Engine light on?, seems like ecu is on limp mode and only allowing you that high rpm to prevent from any engine damage
Old Apr 2, 2016 | 12:35 PM
Yea but the only codes are for O2 Sensor and a check valve
Old Apr 2, 2016 | 12:48 PM
DA9_LEO's Avatar
need to solve the codes and then reset ecu and hope limp mode goes away,
StephanHalas
Apr 2, 2016 03:17 PM
StephanHalas
Apr 2, 2016 11:03 AM
Greenlantern16
May 27, 2010 11:04 AM
armanian
Feb 22, 2006 11:54 AM
