Gasket issues
Old Apr 1, 2016 | 06:00 PM
DerekHollister's Avatar
Default Gasket issues
I have a skunk2 pro intake with 68mm throttle body. I have a gasket that I've been told is wrong and that it doesn't fit right and causes a leak so I looked on skunk2 website and found a gasket they said is for my throttle body so I made it from gasket material you can buy from autozone and the car starts with it idles at about 600 for a split second then dies. What's my issue. Pictures are gasket that leaks on throttle body, the throttle body and the gasket I copied
Old Apr 2, 2016 | 12:09 AM
TheRealTegger's Avatar
Default Re: Gasket issues
The gasket shown on the throttle body doesn't match the one in the Skunk 2 screen shot.
Why wouldn't you just make a gasket that looks like the one in the Skunk 2 screen shot?
Old Apr 2, 2016 | 04:52 AM
I did that's when the car wouldn't stay running
Old Apr 2, 2016 | 04:53 AM
It only runs with the wrong gasket but with a leak
Old Apr 2, 2016 | 05:34 AM
Old Apr 2, 2016 | 02:28 PM
EnjoyTheRideDC2's Avatar
How does that same gasket look when against the throttle body itself?
Maybe use a thicker gasket material.
Old Apr 2, 2016 | 03:50 PM
The one I made?
Old Apr 2, 2016 | 05:35 PM
The one I made fits fine thicker wouldn't have anything to do its a 1/32 wount stay running. Need to fix this but I'm lost what to do
Old Apr 2, 2016 | 05:51 PM
89brokendownEF's Avatar
if its running with the old gasket and not the new it is because the openings, you have 6 holes in the original gasket u made and from what u said with the first gasket you shown it looks like more ventilation for the u shape slit on bottem left and maybe that gasket u say was leaking is beacause on top of ur picutre there is an opening above the gasket. try make custom gasket with slits and holes
Old Apr 2, 2016 | 06:00 PM
Well skunk2 said this is the gasket for the throttle body. I made one before this one it was basicaly identical to the one that doesn't fit and the car would do the same thing
Old Apr 2, 2016 | 09:51 PM
wunfstgsr's Avatar
Loved
Community Favorite
The area in red should be covered by the gasket in black.
Old Apr 3, 2016 | 06:26 AM
That's weird because on skunk2 website it shows this one
Old Apr 3, 2016 | 04:25 PM
Why not just buy the skunk2 gasket to see if it solves your problem?
Old Apr 3, 2016 | 05:01 PM
Thought about it still wanna talk to skunk to and make sure this is it because the only port on the intake is the iacv even tho I don't have one.
trailblazer
Jul 9, 2018 08:22 PM
bigweedy
Dec 29, 2009 01:13 PM
honda06si
Honda Civic (2006 - 2015)
Aug 3, 2006 02:10 PM
bootlegtrader
Feb 3, 2006 07:17 PM
