Is it harmful to relocate my battery to hatch?
Old Apr 1, 2016 | 08:14 AM
Highny's Avatar
Default Is it harmful to relocate my battery to hatch?
Hi there,
I've been wanting to relocating my battery to the trunk for sometime now so I finally did some research and bought some material. Unfortunately I hit a snag and need to clarify a few things before working on it.
I read that car battery release explosive gasses when being charge and discharging. Which is why it is recommended you vent the battery box in the trunk. So my concern is that since my civic is a hatchback without backseats(most I've read are sedan), would the battery fume cause an issue if the box is vented to the cabin?
Any help/clarification would be greatly appreciated.
Thanks
Old Apr 1, 2016 | 08:29 AM
DA9_LEO's Avatar
Default Re: Is it harmful to relocate my battery to hatch?
I have a 1991 Integra and my Battery is relocated to behind my passenger seat, I will be drilling a hole with a tube and venting battery to under car, as long as you properly vent the batter out of the car you should be fine,
Old Apr 1, 2016 | 08:54 AM
JustADaily's Avatar
Also i know the longer the wire, the more current youll loose. Just keep the wires short as possible.
Old Apr 1, 2016 | 09:29 AM
Highny's Avatar
The battery box I got has big venting ports on the side so it's not sealed in a way I could connect it to a tube and venting it to outside of the car, hence my dilemma.
Old Apr 1, 2016 | 10:37 AM
DA9_LEO's Avatar
Same issues I am currently having with my Battery Box, I will be drilling a 1/2'' hole and run a tube to outside of car for extra ventilation, so its just an idea id drill on the side of box
Old Apr 3, 2016 | 02:56 PM
Tyson's Avatar
battery relocation is a stupid mod. does nothing for you. why do ppl bother...
Old Apr 3, 2016 | 04:03 PM
Highny's Avatar
I know it does nothing but I like the look of a less cluster engine Bay.
Old Apr 4, 2016 | 07:45 PM
Bently_Coop's Avatar
Steve at Heart
Run a sealed AGM battery like the Odyssey PC680 and you won't have to worry about venting. You can get the hold downs cheaper then what I linked.
Amazon.com: Odyssey PC680-P  Battery: Automotive Amazon.com: Odyssey PC680-P Battery: Automotive
Amazon.com: Odyssey PC680 Hold Down Beiter DC Power®: Automotive Amazon.com: Odyssey PC680 Hold Down Beiter DC Power®: Automotive
Edit: Here is a picture of mine mounted on the frame rail.
Old Apr 6, 2016 | 12:20 PM
whited's Avatar
CRX God
My main concern with relocation is safely securing the battery. I'm very concerned with it coming lose during an accident and having a 15lbs weight free and behind me. I've made some beefy supports when I relocate. I didn't vent, and didn't die. But then again I am a god, so that could be why I haven't died.
Old Apr 6, 2016 | 05:03 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I use Shuriken sk BT 20 batteries, EXACT same battery as the Oddysey for about 1/2 the price.
Shuriken SK BT20 600 Watts 20 Amp Hours Compact Size AGM 12V Power Cell Battery | eBay
Old Apr 7, 2016 | 06:29 PM
acmoc's Avatar
Just get a lightweight battery instead
Old Apr 8, 2016 | 12:15 PM
menappi's Avatar
Get a smaller battery. I picked up a tiny one made for a riding lawn mower (I think?) back when I had my rex and it free'd up a lot of room.
Old Apr 8, 2016 | 02:16 PM
whited's Avatar
CRX God
Yeah that is a bad idea, you should just use an old cell phone battery.
Old Apr 9, 2016 | 10:40 AM
bheinen74's Avatar
agreed.
this thread should be titled: There is no benefit to relocate a battery.
Old Apr 9, 2016 | 10:58 AM
Highny's Avatar
Like I said earlier in the post. I want to relocate the battery purely for aesthetics. I want to slowly tuck my wires away. Therefore it's relocating the battery is the first thing on the agenda. If you don't have any comments that helps please keep them to yourself.
Thanks to those who gave some suggestions. My solution to the large vent on my battery box is to get a sheet of see through plastic(not sure what they are called), cut to size and replace it for the lid piece. Then cut a hole on the side of the box for venting and wires.
Old Apr 9, 2016 | 04:26 PM
fcm's Avatar
fcm
Old Fart
A sealed batt/ like ones mentioned is the best way or a sealed batt. vented to the outside.
Defiantly mount it solidly, watch your cable gauge, cable gauge will depend on length.
Do not use splitters run the batt .cable from batt. pos.[+] post directly to the starter motor, run a 6ga from the starter, [same terminal] to the engine bay fuse box.
A fuse/breaker needs to be installed on the batt. cable as close to batt. as possible.
Your done. 94
Old Apr 9, 2016 | 07:15 PM
Highny's Avatar
Originally Posted by fcm
Your done. 94
Not quite, how would you wire up your alternator? Would you also fuse the alternator?
My current plan is
Battery - fuse box(150amp) - distributor - one to starter, one to fuse box, one to alternator(with a 80amp fuse).
This is just what I found on google search.
Old Apr 9, 2016 | 08:01 PM
acmoc's Avatar
if its for aesthetics why get a huge eyesore vent box
Old Apr 10, 2016 | 09:19 AM
Highny's Avatar
Well, that was a mistake on my part. I didn't measure my battery before ordering the box. Now that I have it I'm trying to make the best of it.
Also it's in the rear so I don't really see the thing.
Old Apr 11, 2016 | 01:17 PM
acmoc's Avatar
I mean,
vent box, extra cable, possibly losing resistance, harmful gasses
You're adding weight
function>form
Best to get a lightweight sealed battery if you're still going to relocate.
_MG_1905 by [i]van, on Flickr
_MG_1896 by [i]van, on Flickr
Old Apr 11, 2016 | 01:26 PM
whited's Avatar
CRX God
I mean,
function>form
@acmoc what type of oil cap is that?
Old Apr 11, 2016 | 01:30 PM
acmoc's Avatar
It's a mugen. The metal decal got damaged from antifreez so I just machinesd it all level.
I had it clear coated alluminum then painted it black. I might strip the black paint
Old Apr 12, 2016 | 06:04 AM
whited's Avatar
CRX God
I like it!
Old Apr 12, 2016 | 07:57 AM
fcm's Avatar
fcm
Old Fart
My current plan is
Alt. stays wired to engine bay fuse box, no other fuses are needed.
Adding the "distributor" just adds connections that are not needed, every connection in a point of resistance, and potential fail point. 94
Old Apr 12, 2016 | 09:40 AM
bheinen74's Avatar
harmful, probably.
dangerous, likely
bbq chance, high
