Need advice: '92 VX, crank pulley and crankshaft end stripped
Old Mar 31, 2016 | 05:44 PM
calCW's Avatar
Default Need advice: '92 VX, crank pulley and crankshaft end stripped
Hey, all.
I've got a '92 VX that's been my daily driver for 10+ years (it's the second VX I've owned.) The engine is original, with 180K miles, though the head was replaced at about 90K miles.
So here's the issue: The engine itself has been running fine, but the main crankshaft pulley (NOT the timing belt pulley) just stripped out -- the key sheared off and and tore up the end of the crankshaft.
So basically, as far as I can see, the whole crankshaft would have to be replaced. I'm told that on this model of Civic, this can be done by removing the oilpan, without tearing down the entire engine, but it's more than I want to take on, so I'd be paying a mechanic friend to do it.
What I'm trying to decide is... would I be better off, if I decide to fix it, to simply find another used D15Z1 engine and swap it out, or would I be better to replace the crank? And if I do replace the crank... should I go ahead and replace the rod bearings and so forth? Where do I draw the line between fixing the problem and rebuilding the entire engine?
My concerns with a used engine is not knowing what I'm getting, and I've also heard some horror stories about buying rebuilt engines, so really I just need suggestions and advice.
Any input appreciated!
Old Mar 31, 2016 | 06:01 PM
Former User's Avatar
Default Re: Need advice: '92 VX, crank pulley and crankshaft end stripped
Post pics.
Old Mar 31, 2016 | 09:39 PM
eghatch9295's Avatar
Stancetard Hate Monger
if you want a quick, cheap fix, slap another d series in there and call it done. throwing a used crank in it with some bearings is probably not the best of ideas, you're venturing into machine work time territory.
Old Apr 1, 2016 | 11:25 AM
jooky5's Avatar
find a spare vx engine and have that dropped in
Old Apr 2, 2016 | 10:55 AM
94EG8's Avatar
Seagull Management
Get another crank pulley and a new key, put it on, grind down a finishing nail or something similar to jam in between the key and the crank pulley where the keyway is damaged, cut this to length and tap it in. Put some green loctite (shaft and bearing mount) on the crank pulley bolt and crank it in with a good 1/2" impact as tight as you can get it. Keep driving it until it comes off again.
NACvicSi
Aug 28, 2008 01:12 PM
street_ride14
May 13, 2007 04:35 PM
Charlie Moua
Jan 6, 2006 07:55 PM
Thrillhouse
Jun 6, 2005 06:07 AM
boomslang
Jun 16, 2003 06:24 PM
