Broke off temp sensor in engine
Old Mar 31, 2016 | 05:47 AM
PINKYSBBQ's Avatar
Icon5 Broke off temp sensor in engine
Ok i took out the one temp sensor in my 90 civic wagon 1.5l
i put new one in an it broke off. i can not figure out how to get the thread casing out of the hole god i am no good at this stuff someone please help me so i don't mess up the head. an if all possible not have to take the head off.
Old Mar 31, 2016 | 06:04 AM
1991civiclx13's Avatar
Default re: Broke off temp sensor in engine
could try using an extractor...?
Old Mar 31, 2016 | 06:18 AM
PINKYSBBQ's Avatar
were would i get one? an what do they look like? i am not very mechanical
Old Mar 31, 2016 | 06:23 AM
kp's Avatar
kp
Spoon fed.
Here's How To Remove A Broken Bolt Without Losing Your Mind
Bolt, sensor, stud...same thing. Go slow and be gentle.
Old Mar 31, 2016 | 06:28 AM
PINKYSBBQ's Avatar
ok thank you i will go buy i a set right now to try this if this does not work any other solutions?
i am scared to death i ruined this head. i can not afford to buy a new one or anything like that.
Old Mar 31, 2016 | 06:34 AM
kp's Avatar
kp
If you can't do it or feel that you cannot do it, then don't try. With these situations you usually get one really good shot at it, and then it only gets harder.
Call a friend, a friends friend, your mechanic, your plumber buddy, anyone with any sense of mechanics and proper use of tools. Worst case, get it towed to a machine shop and have them remove it for you.
Old Mar 31, 2016 | 06:35 AM
extractors can be bough at your local hardware store
Old Mar 31, 2016 | 07:03 AM
PINKYSBBQ's Avatar
ok great news i got it out damm i am happier then a pig in slop!!!!!!!!!!!!
next question? the sensor that tells the fans when to kick on is that one of the sensors on the head? i changed the coolant temp sensor an was in the process of changing the other when it broke. i hope one of these is for the fans? if not where is it located at?
Old Mar 31, 2016 | 07:40 AM
24TEN's Avatar
PHANTOM MENACE
Should be rear middle of the block just above the oil pressure sensor and oil filter, if I remember correctly it's a green two pronged connector.
Old Mar 31, 2016 | 01:08 PM
PINKYSBBQ's Avatar
Icon5 re: Broke off temp sensor in engine
ok i changed the sensors an the thermostat to no avil has it fixed the problem. the problem is that the lower hose going to thermostat
is staying cold behind the thermo it is hot fans kick on nut according to the hand held temp gauge the hottest spot i found was on the block at about 180 degrees upper hos is about 130 lower is about 81 i have let it idle for ever to try to get air out of bleeder but the flow never comes any ideas?according to the temp gauge it is where it should be almost a halfway POINT. head gasket was changed an there are no leaks anywhere, this thing is driving me crazy i should of stayed with an american car
Old Mar 31, 2016 | 01:54 PM
What thermostat did u use as a replacement? Check to see if it's opens and closes at the right temperatures. Also try bleeding the air out of the system from the radiator cap once you make sure you have the right thermostat.
Edit: it should start opening at 172*Fand fully open at 194* F
Old Mar 31, 2016 | 02:40 PM
PINKYSBBQ's Avatar
it is an ome 180 i have changed it 3 times an nothing has changed.
i had the bleeder open for almost an hour while it was idling an it never spewed out like it should, you open it up a little comes out (about half a cup to a cup full) then it just stops. i even had the cap off while it was idling an no change. like i said it is not over heating. i was thinking about loosing the cap an driving it for a little while to see if that would work. at this point anything or suggestion would help
Old Apr 2, 2016 | 05:40 PM
89brokendownEF's Avatar
Default Re: Broke off temp sensor in engine
hey if you dont want to *** with trying to extract it just run it like these guys did heres this link its on honda tech pictures of two different very helpful
https://honda-tech.com/road-racing-a...ation-2797951/
Old Apr 2, 2016 | 07:19 PM
PINKYSBBQ's Avatar
Icon5 Re: Broke off temp sensor in engine
this is what i am trying to figure out please any help would be grateful!!
is staying cold behind the thermo it is hot fans kick on according to the hand held temp gauge the hottest spot i found was on the block at about 180 degrees upper hos is about 130 lower is about 81 i have let it idle for ever to try to get air out of bleeder but the flow never comes any ideas?according to the temp gauge it is where it should be almost a halfway POINT. head gasket was changed an there are no leaks anywhere, this thing is driving me crazy i should of stayed with an american car
Old Apr 3, 2016 | 03:48 AM
the temp gauge sound only be at most a little more than a quarter, seems like your thermostat may be stuck, install temp sensor in diff location like others did in previous link and if your worried about it overhearting. just put a switch so you can turn the fan on when you want. how mine is set up. my switch even lights up blue its a skull
Old Apr 3, 2016 | 05:27 AM
PINKYSBBQ's Avatar
ok i am not explaining this right so i will try again,
i put a new head gasket on the car,a new 180 degree thermostat and i have changed it 3 times and just so everyone knows it is not a fail safe thermostat ,an other stuff.
the car runs great no leaks what so ever, the problem is that the lower radiator hose is staying cold with a temp of about 81 degree before the thermostat. after the thermostat the temp is about 153 degrees.
now the top of the radiator is at 183 degrees. the engine is not getting hot the temp Gauge in the car reads where it should but when the gauge reaches the right temp in car, the fans come on an stay on the do not cycle off and on.know this is what i am trying to figure out what the heck is going on.
1. why is the lower hose stay so cold?
2.why are the fans constantly staying on? And
3. is the reason it is not flowing right because of the fans on all the time
or is it something else that i am missing.
I have put over 100 miles on this car since i changed the head gasket an has never over heated. but like i said lower hose stays cold an fans run all the time. this is what i need some help with.
Old Apr 4, 2016 | 06:25 AM
if your having this many problems just take it into shop and have them look at it, honda does diagnostic for $50... sometimes paying a little $$$ is worth the saved headace.
Old Apr 4, 2016 | 06:32 AM
PINKYSBBQ's Avatar
well i would like to thank you all for helping me with your info was very helpful,
but sad to say the 1.5L motor has died i went for coffee in it this morning an it threw a rod through the block go figure well i will be scraping the whole F'ing thing now. but i guess this is life once again thanks for your help
Old Apr 5, 2016 | 06:42 AM
where do you live do not scrap the ef ...... i would never scrap one..
Old Jan 4, 2021 | 05:56 PM
Chevelle T's Avatar
I was putting my temp sensor back i guess i tight,en to much and the copper broke off inside the engine, how do i get the copper piece out. ?????? help any ideas.
Old Jan 7, 2021 | 08:12 AM
DaX's Avatar
DaX
Loved
Community Favorite
Use a broken bolt extractor set.
02_Civic
Honda Civic (2001 - 2005)
Nov 9, 2015 10:57 AM
dunked dc
Jan 29, 2011 01:32 PM
titi_vtec
Oct 21, 2010 08:56 AM
syphonp2
Sep 23, 2009 07:17 PM
hatchofdoom
Jul 20, 2007 12:47 PM
