Transmission & Drivetrain Gearboxes, Differentials, Clutches
need help! 2000 civic auto
Old Mar 30, 2016 | 02:56 PM
JDM_DAKiD's Avatar
Default need help! 2000 civic auto
My civic jerks/shifts hard when it shifts. What can be the problem? (All mounts seem to be good) thanks in advance
Old Apr 23, 2016 | 05:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: need help! 2000 civic auto
Check the fluid. If it has not been changed, drain, refill, drive X3 to get most of the old fluid out.
Verify no codes are stored. Not all codes will set off the CEL or D4 lights.
If the transmission has a throttle valve cable to the throttle body, verify it is properly adjusted. No slack and no preload.
Check the right side cover and look for the shaft speed sensors. Pull them out and verify they are clean and free of junk. If they have ferrous material on them the PCM will not be able to know what the shaft speeds are and shifting can become harsh and/or erratic.
Verify the shift solenoid screens are clean, verify the shift solenoids work by applying battery voltage directly to the solenoids. They should turn on/off with a solid 'click'.
If the transmission checks out, verify the engine is in proper working order. Engine health greatly affects transmission shifting and shift quality. Something as simple as a faulty TPS may not set off the CEL but will cause late shifts that may be considered harsh.
thaxton8410
Honda Civic (2001 - 2005)
35
Apr 21, 2024 04:26 PM
Carolina Tiger
Feb 16, 2008 02:03 PM
D50boy
Jul 21, 2007 10:24 PM
random_orbit
Apr 11, 2006 06:41 PM
KoRE
Mar 31, 2002 09:16 PM
