no fuel no spark
Old Mar 29, 2016 | 02:36 PM
beastmode75's Avatar
Default no fuel no spark
I have a96 gsr sedan. Ive replaced the fuel pump main relay starter and distributor. But im not getting a spark or any fuel. Anyone know why?
Old Mar 29, 2016 | 04:28 PM
tamboo's Avatar
10 Year Member
Default Re: no fuel no spark
Starting Problems
Old Mar 29, 2016 | 10:07 PM
Hieb_dc4's Avatar
^Very good resource
Old Apr 1, 2016 | 02:05 AM
trm4life's Avatar
Start with your check engine light, does it stay on? If so the problem is your ECU! If the light goes off, and you dont hear the relay/ pump, it's likely the relay under the driver dash. If you still have problems, check your battery to body ground, and the ground wire for your ECU which is located on thermostat housing on my Integra. Yes, it is supposed to be on the housing not the block. Aluminum is not a great conductor of electricity, but the screws are steel, and electricity travels through water. Make sure your connections are solid, metal is clean, and afterwards apply some liquid electrical tape to avoid future corrosion.
EJ1 Ekenziro
Jan 1, 2019 02:27 PM
808civi
19
May 29, 2016 05:42 PM
fordboy15
19
Jun 3, 2013 06:21 PM
vtec8200
Jul 16, 2012 03:16 PM
dan617
10
Jan 31, 2009 02:10 PM
