00 Civic/B18 swap - stumbles and sputters
Car is a 2000 civic si with a JDM type r b18c. ECU is a p28 chipped with hondata v3. Also has the hondata coilpack retrofit. When the car is cold it will stumble at about 3k rpm and sputter with continuous throttle until it gets warmed up and then it's fine for the most part with the occasional stumble here and there. Any idea what it may be?
I was thinking it could be the tune due to the previous owner having it tuned by a friend rather than having it tuned professionally at a reputable tuning company
It's basically a distributor without the cap
It's this: https://www.hondata.com/coil-pack-retrofit
Nobody?
Nobody?
Can I remove the distributor?
No. It is needed for the timing signals. See the CPR help file for more details.
I know tuning can be expensive to have it done professionally so I just wanted to see if there was something stupid I was missing before I shell out a chunk of change and hope it wasn't tune related!
If it helps, whenever it is really warm the car behaves perfectly. For example, today is 70 degrees and the car has run perfect without any issues. It was 40 the other day and it ran pretty badly. Big difference. Any correlation?
ruby civic II
Jul 5, 2006 01:53 PM
