Brake fluid leaking
Old Mar 28, 2016 | 06:00 PM
Tony Nguyen's Avatar
Default Brake fluid leaking
Hello there, I have a 95 b18c del sol. It's leaking brake fluid. I checked all the bleeder, visual inspection to see any external leaking but I couldnt find anything. Any suggesion?
Old Mar 28, 2016 | 07:34 PM
hondur's Avatar
Dur Da Dur
5 Year Member
Default Re: Brake fluid leaking
refill the fluid reservoir, get the car up in the air, start it up and pump the brakes. You'll find the leak eventually, just make sure the reservoir stays full or else you'll end up pumping air out of the hole in the brake system and you won't find the leak. That's sort of a 'durrr' moment.
Old Mar 28, 2016 | 09:00 PM
wraprail's Avatar
Check where the master bolts to the booster. Pretty common for the master to leak and it runs down the front of the booster under the master. Look for peeling paint on the booster
Old Mar 28, 2016 | 09:04 PM
wraprail's Avatar
Like this............
Old Mar 28, 2016 | 09:49 PM
Bently_Coop's Avatar
Steve at Heart
Do you have a flare wrench set? I would tighten or check all of the fittings, lines, bleeders, and proportioning valve.
Some Home Depot's carry this set.
http://www.homedepot.com/p/Husky-SAE...W6PC/203541511
Old Mar 28, 2016 | 11:32 PM
MisereNoire's Avatar
you might also double check your proportioning valve to see if there's seepage from in between the two halves of the body.
eh9deux
17
Jun 13, 2011 07:33 AM
stripes777
Oct 28, 2006 11:16 PM
jdmsteve2004
May 31, 2004 12:20 AM
mrpeabody
Mar 19, 2004 06:50 AM
Driven
Jul 23, 2003 06:21 AM
