Civic em1 swap b20z2
Hey guy I Just bought a civic si 2000 swap b20z2 there is a 0bd1 p75 ecu in it and it is in limp mods what should i do ship it? And also wath the obd version with the stock motor should i get a full harness swap
try cleaning it. the sensor is not complicated its a magnetic pickup theres barely any parts.
the plug and sensor gets dirty with oil and it stops working intermittently which throws a code
make sure its the right plug that's plugged into it
what harness are you using?
Information :: Tech Area :: Check Codes
If your throwing a solid malfunction indication light with & without the 2 wire service jumper jumped, you may have a wiring issue or bad ecu.
To get the most out of the b20z2 you should have the obd1 p75 ecu chipped for your application (assuming it's working properly).
Ecu Chipping Service - Phearable.net
I will try that and i dont know what the harness it was alredy ther when i bought the car so
Jose-aka-Pedro
May 18, 2006 09:50 PM
FLIPboi
Oct 14, 2004 11:25 AM
