Transmission & Drivetrain Gearboxes, Differentials, Clutches
Trans grinding when not pressing gas
Old Mar 28, 2016 | 08:13 AM
00civic-ej8's Avatar
Default Trans grinding when not pressing gas
Ok wussup guys haventh been on here for a while and got rid of my 00 ej8 and just picked up a 4 door civic 95 5 speed so here is my problem
Ok so the trans is a 5 speed its got a d15b7 if that matters but when i go in gear and drive and press on the gas and go about my business everywhere i go it wonth grind but when i let go of the gas while im on gear it almost sounds like when ur brake pads are metal to metal ( and no i dnt press on the brake pedal when i let go of the gas) and it does it in mainly all of the gears but barely of 5th just want some insight on what it could be before i say duck it and buy another used trans and just put that one in thanks in advance
Old Apr 12, 2016 | 10:41 AM
Default Re: Trans grinding when not pressing gas
Well just in case anybody was curious i went ahead and bought a used trans form jdmenginecorp in richardson tx and when i removed the trans the input shaft almost had more than a 1/4 inch of play all around so the trans is in also put new axles in it since they wer pop locking and dropping on every turn i made and new exery clutch drives like it should bow
Golferdude1977
Dec 18, 2007 03:36 AM
ekinshuya
11
Aug 23, 2007 10:27 PM
Steven.
Aug 28, 2006 06:06 PM
itbqik
Honda S2000
40
May 4, 2006 09:24 PM
swartz
Mar 10, 2005 08:40 AM
