You'll need to use the B-series axles with your swap. They will fit into the Si hub. The half shaft is located on the back side of the engine below the oil filter on the B18B1.
B-series axles are equal lenght and use a half shaft.
D-series axles are unequal lenght and have no half shaft.
You can see the two axles and the half shaft (intermediate shaft).
