Full Race Manifold Revision B
Old Nov 6, 2002 | 11:02 PM
Full-Race Geoff's Avatar
Default Full Race Manifold Revision B
This is the Revision B manifold. Meant for race cars.
Old Nov 6, 2002 | 11:20 PM
JDEM1's Avatar
Default Re: Full Race Manifold Revision B (FFgeoff)
Old Nov 6, 2002 | 11:59 PM
The sweed's Avatar
must be a bitch to weld togather.
Old Nov 7, 2002 | 12:38 AM
InfamousRS's Avatar
Default Re: Full Race Manifold Revision B (The sweed)
Geoff, did you make that collector? What makes it for race cars only? Just the position of the turbo?
Old Nov 7, 2002 | 12:41 AM
hungry's Avatar
Default Re: Full Race Manifold Revision B (InfamousRS)
omg ... must be very $$$
looks good
Old Nov 7, 2002 | 03:23 AM
PWRVTEC's Avatar
Whats the cost of that one?
Old Nov 7, 2002 | 05:36 AM
Sinitron's Avatar
Wow... neato collector work !!!
Old Nov 7, 2002 | 05:43 AM
Dublocivic's Avatar
Default Ff
Nice Geoff
Old Nov 7, 2002 | 06:12 AM
POLLO's Avatar
Default Re: Ff (Dublocivic)
Well shiiiiiiet there he goes away.. Showing off dem clean welds..
Old Nov 7, 2002 | 06:54 AM
TurboedGSR's Avatar
Default Re: Ff (POLLO)
looks tack welded.
nice
Old Nov 7, 2002 | 07:10 AM
SiRkid's Avatar
Default Re: Ff (TurboedGSR)
Old Nov 7, 2002 | 07:13 AM
BoostedED9's Avatar
Default Re: Ff (SiRkid)
lookin good
Old Nov 7, 2002 | 07:34 AM
1.8T_EG's Avatar
... i wish i could afford one
Old Nov 7, 2002 | 07:52 AM
Elite Hatch's Avatar
Default Re: Full Race Manifold Revision B (1.8T_EG)
DAMN! thats amazing
Old Nov 7, 2002 | 08:13 AM
ffgeon's Avatar
i pity the fool who has to weld that
Old Nov 7, 2002 | 08:17 AM
BoOsTeD_eK's Avatar
Default Re: Full Race Manifold Revision B (ffgeon)
when will you have the sr20det manifold ready?
Old Nov 7, 2002 | 08:50 AM
That collector is a full-race collector, made in house. My welder is the guy to thank for the beautiful work on that, i couldnt possibly weld that well.
The reason it is for race cars only is that it will orient the turbo so far out, the only intercooler you can use is an air to water, or none. Also it is setup so that the compressor housing inlet will be facing the front of the car so that a hole can be drilled in the bumper and you can use an ASME inlet horn.
Old Nov 7, 2002 | 10:59 AM
InfamousRS's Avatar
It looks like theres about 2-3" right out of the flange that could be taken out to make it a little shorter and accomidate a air-air intercooler....would that mess anything up with the flow of the manifold, if for say someone wanted to run that design on their street car?
Old Nov 7, 2002 | 04:53 PM
turbologist's Avatar
Where does the wastegate go? I'm assuming thats full stainless..Price??
BTW..
Old Nov 7, 2002 | 05:19 PM
Mr. Softee's Avatar
Default Re: Full Race Manifold Revision B (drealboostedhybrid)
I'd give geoff man play for a manifold Crew is taking roll, im member #001
Old Nov 7, 2002 | 05:48 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
hey geoff, who does weld those together, its not who im guessing it is, is it???? GG?
Old Nov 7, 2002 | 06:27 PM
TheShocker's Avatar
Default Re: Full Race Manifold Revision B (SIXTYdashONE)
Beautiful collector! nice work, Geoff!! Is that 321 by any chance?
[Modified by TheShocker, 9:28 PM 11/7/2002]
Old Nov 7, 2002 | 07:43 PM
FFgaeson's Avatar
also it should be noted the length of the manifold with turbo will bring it well in the way of the stock honda rad support, another reason why its gonna be race only...
surprisingly this manifolds weighs less than the non race manifold...
as for intercoolers... who needs them when you got methanol.
Old Nov 7, 2002 | 07:44 PM
Pelican's Avatar
Default Re: Full Race Manifold Revision B (TheShocker)
another sweet mani
Old Nov 7, 2002 | 08:06 PM
FredoSP's Avatar
Default Re: Full Race Manifold Revision B (ffgaeson)
well said
