1998 Civic EX Power Window Problem
Old Mar 23, 2016 | 08:34 AM
Jakester9500's Avatar
Default 1998 Civic EX Power Window Problem
Car: 1998 Honda Civic EX
Problem: The passenger side window won’t go up or down but the driver window does. The window will go up and down if I put straight power to the window motor.
I checked the 40 amp fuse under the hood and a couple fuses under the dash that said PW thinking it might be power windows. I checked the wiring inside the door and everything seems to be intact.
Also tried another switch on the passenger door. And the driver door switch doesn't put it down either.
Any idea’s what this can be?
Old Mar 23, 2016 | 09:46 AM
Former User's Avatar
Default Re: 1998 Civic EX Power Window Problem
Is the main switch turned OFF?
Also test fuse 10.
Old Mar 26, 2016 | 04:03 AM
Where is the main switch?
All the fuses under the dash and under the hood appear good.
Old Mar 26, 2016 | 04:04 AM
I'm going to try switching the driver side switch out for one that I know works. I'm thinking maybe its not completing the circuit.
Old Mar 26, 2016 | 05:31 AM
civic402lx's Avatar
Check door harness for crack, split, fray wires.
Old Mar 26, 2016 | 04:33 PM
The main switch is in the driver's master switch. See diagram.
Fuses that appear to be good can be bad. Voltage test fuse 10.
https://honda-tech.com/honda-civic-d...fuses-3079359/
Old Mar 28, 2016 | 07:57 AM
dsol's Avatar
had similar problem, but sometimes it would go up and down just VERY VERY slow/weak. checked wiring to door and found my connector where the harness enter the doors was cracked.
SiHatchTurbo
Apr 1, 2012 12:34 PM
v-tecnition
Oct 6, 2008 01:19 PM
aktc167
May 10, 2005 07:33 PM
BauleyCivic
May 1, 2005 04:42 PM
steven975
Honda S2000
May 3, 2004 04:37 PM
