Burnt ATF: to change or not to change?
Old Mar 21, 2016 | 11:47 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Burnt ATF: to change or not to change?
Might seem like an obvious question, but this is an argument older than the internet. I acquired a new, fancy beater that may have never had its transmission serviced. Fluid is mostly brown, trans doesn't slip, but does shift a little harder than it should. Due to the horror stories of people flushing their very dirty fluid and replacing it with new, only to have their trans fail quickly, I wanted to ask you guys your opinion. Let it rip.
Old Mar 22, 2016 | 03:59 AM
hondur's Avatar
Dur Da Dur
5 Year Member
Default Re: Burnt ATF: to change or not to change?
If you're gonna put crappy ATF in it, don't do it.
If you're gonna put Amsoil in it, then change it.
P.S., don't forget to install a magnefine filter
Last edited by hondur; Mar 22, 2016 at 04:00 AM. Reason: I'm confident that the entire idea that changing ATF is bad came from people using crappy ATF.
Old Mar 22, 2016 | 04:04 AM
Bently_Coop's Avatar
Steve at Heart
I would change it and do the recommended flush procedure. I used Valvoline import fluid and then OEM Honda fluid for mine. Works just fine after 18k miles. When I got the car it was manually shifted between two gears.
I think RonJ has mentioned the Castrol Import stuff works well too.
OP- post your year and engine in the original post as well. Required for tech threads.
Old Mar 22, 2016 | 04:15 AM
tony_2018's Avatar
Fish Twig
Op missing info.
Old Mar 22, 2016 | 05:33 AM
Former User's Avatar
Three consecutive ATF drain-refill cycles. Between each drain-refill cycle, slowly shift through all gears several times with the engine running.
cabtank@aol.com
Jun 11, 2019 08:37 AM
eddieE
Honda Civic (2006 - 2015)
Feb 4, 2013 05:12 PM
dan_g
27
Oct 5, 2009 03:06 AM
businessmanph
Acura TL, RL & ZDX
Sep 8, 2006 01:57 PM
Razor
Honda S2000
13
Sep 18, 2003 02:16 PM
