d16y7 no fuel no spark (solved)
Old Mar 21, 2016 | 12:09 PM
shaquilllis's Avatar
Default d16y7 no fuel no spark (solved)
Drove home one day and parked. Next day car doesn't start. So far I have replaced the ecu and main relay. Main relay tested bad so I swapped it. Can't figure this out. Any help is appreciated!
Old Mar 21, 2016 | 03:02 PM
Former User's Avatar
Default re: d16y7 no fuel no spark (solved)
Car information is required for all tech threads.
Old Mar 21, 2016 | 03:15 PM
Cdaleadams's Avatar
Check the ground that bolts to the back of the thermostat housing.
Old Mar 22, 2016 | 03:27 AM
tyler8469's Avatar
What lead you to replace the ecu?
Have you checked the car for spark? Can you hear the fuel pump running? Does the car have any alarm system hooked up?
Old Mar 22, 2016 | 11:01 AM
Just to clarify I was getting no spark and no fuel. Pump was not priming. I had previously checked the thermostat ground but it seemed ok. Went back and checked it again and found it was rusted to the point where it wouldn't work. Cleaned it up and everything is working fine again. Hopefully this will help people in the future
Old Mar 22, 2016 | 11:04 AM
tyler8469's Avatar
Good info. Glad things are up and working. Cheers.
dan617
10
Jan 31, 2009 02:10 PM
crxowner
Oct 2, 2007 05:49 PM
DumpedSi
13
Nov 29, 2006 09:17 PM
Down Shift Motoring
Mar 11, 2006 05:32 AM
QuickTypeR
Nov 23, 2004 08:52 PM
