Achieving smooth idle with IACV disabled.
Old Mar 20, 2016 | 08:11 PM
Zympress's Avatar
Default Achieving smooth idle with IACV disabled.
I have disabled IACV error on crome, but I still get a fluctuating idle. My car has a 3 wire IACV, I dont want to convert it. I just want to find a disable it and get a smooth idle. How is it that IACV-less ITB setups achive this?
Old Mar 20, 2016 | 09:38 PM
motoxxxman's Avatar
Default Re: Achieving smooth idle with IACV disabled.
what motor are you running?
and when you say the idle is fluctuating, what rpm range does it fluctuate between?
Old Mar 20, 2016 | 09:54 PM
turbohatch96y7's Avatar
Manipulate the timing if you can
Old Mar 21, 2016 | 01:26 PM
Zympress's Avatar
Motor is a y7 with a automatic y8 manifold, so it uses the 3 wire IACV. The idle either maintains at 2k rpms or fluctuates between 1k and 2500 rpms. It runs perfectly fine with the stock computer. It's a P2E, I'm using a chipped P72 with everything disabled including IACV error. Wouldn't the idle depend on the idle screw on the throttle body? Or is the IACV still a factor on the idle even if I disable the error?
Old Mar 21, 2016 | 04:26 PM
motoxxxman's Avatar
when the iacv is unplugged, it should remain closed. though it may be dirty and stuck open a little.
if it idles fine with the stock ecu, but idles high with the chipped p72, then you have the base timing in the chip set way too high. timing, fuel, and air volume all contribute to the idle rpm. and when it bounces, it's because it's idling up high enough to high fuel cut.
Old Mar 21, 2016 | 06:38 PM
Zympress's Avatar
Crome sucks for me since I can't tune it in real time. I guess I'll just get a demon and tune it on neptune. I like the fact that I can do ignition cut only on neptune. That for me makes it a far better option than Hondata.
Old Mar 21, 2016 | 08:41 PM
motoxxxman's Avatar
you can do ignition cut only with hondata.
and when I said fuel cut, its a parameter in stock ecus and most modded ecusno matter what hardware/software you use, where it cuts fuel if you're at 0% throttle and over a certain rpm.
you should also probably check your distributor adjustment. if its too advanced it will have the same effect as the base timing in the map being too far advanced.
Old Mar 22, 2016 | 10:19 AM
Zympress's Avatar
Most likely is the dizzy that's too advanced. Im going to adjust it with the timing gun.
Run Away
Mar 11, 2006 05:08 PM
turbotime
Oct 24, 2005 12:01 PM
