97 Del Sol brakes
Old Mar 19, 2016 | 11:04 AM
SoFlaNut's Avatar
Default 97 Del Sol brakes
I have a soft brake pedal. I've changed the brake pads put in a new brake booster and new master cylinder. Master cylinder was bench bleed. The lines have been bleed several times, no air. I haven't changed the proportional valve, no signs of leaking. There are no leaks at the wheel cylinders.
Thinking I may have a bad master cylinder, looking for suggestions..
Old Mar 20, 2016 | 07:02 AM
Former User's Avatar
Default Re: 97 Del Sol brakes
Sometimes bleeding can be tricky, so don't rule that out.
Old Mar 21, 2016 | 12:11 AM
Nave43's Avatar
I had (have) the same problem on my 93 Delsol Si. Replaced MC w/ a larger 7/8 MC, pads, rotors, Bled it for days, everything seems fine. Soft pedal is still there, I just got used to it.
I personally blame it on old rubber brakelines expanding under pressure because its not as bad in the winter.
Old Mar 21, 2016 | 02:12 AM
JarvisW's Avatar
Sol to Sol
How's the check valve? If its leaking the pedal will start sinking, tho same with bad booster iirc.
Old Mar 21, 2016 | 06:45 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Did you use the proper bleed sequence?
eH.
Old Mar 21, 2016 | 04:30 PM
SoFlaNut's Avatar
eH.
Yes
Old Mar 21, 2016 | 04:34 PM
SoFlaNut's Avatar
Going to rebleed the brakes again. If that doesn't work will take MC back under warranty and go from there.
JonasG93
18
Apr 21, 2015 07:22 AM
ribal_gh
11
Apr 30, 2013 04:24 AM
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
ThaCivicAssassin
Aug 12, 2007 12:26 AM
Mandeep
Aug 17, 2005 06:23 PM
