Civic EG e-brake question.
Old Mar 18, 2016 | 01:42 PM
Kurbys's Avatar
Default Civic EG e-brake question.
The parking brake is bolted on to the chassis by 3 bolts right? Is it possible to put a spacer there to raise the parking brake up about 2 inches? Will it affect anything?
Old Mar 18, 2016 | 01:48 PM
Kurbys's Avatar
Default Re: Civic EG e-brake question.
Sorry for shitty phone camera but this is what im trying to do. RSX center console in an eg
Old Mar 18, 2016 | 02:16 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
What it that, a prelude console?
eH.
Old Mar 18, 2016 | 10:38 PM
MisereNoire's Avatar
Yes, you can add spacers/brackets in there to raise height and adjust fwd/bkwd. You won't have a problem if the change is within the adjustment distance the cables/cable tensioner can handle, BUT, too much of a change in distance and you will need to source longer cables. That being said, a slight change in angle of the cables at their entry point into the cabin will not affect them negatively. You might have to forgo spec in the adjustment of your brake cables, and they will be tighter at a lower handle pull position.
machinegunkelly
Oct 23, 2012 04:03 PM
JDean6pac
Jul 6, 2006 09:36 PM
mnbv
19
Jul 2, 2004 03:04 PM
Sassafrass
Mar 3, 2003 06:31 PM
bronzeJDMhatch
Dec 2, 2002 06:53 PM
