Help w/ my Integra just picked up
Old Mar 17, 2016 | 02:50 PM
JDM_WHR's Avatar
Icon5 Help w/ my Integra just picked up
Just picked up a 95 LS
Came with Skunk2 coilovers slammed to ground. The guy lost the forks to adjust them. Anyone know how to adjust them w/out them ?
Also the sunroof won't move at all. I put in a new fuse and nothing happens at all. Is there a DIY or anything to replace the motor/ where is the motor located ?
Lastly the Odometer doesn't work too. Not sure if it's the cluster or the odometer itself. Any suggestions on how to. Check ??
Any help would be greatly appreciated.
Old Mar 17, 2016 | 02:58 PM
MotorMouth93's Avatar
10 Year Member
Default Re: Help w/ my Integra just picked up
To get to the sunroof motor you have to take down the headliner, and then the whole sunroof assembly will unbolt. However, you can turn the motor by hand if you remove the round plastic cap in the middle of the headliner, underneath it is an allan bolt connected to the motor, so if it's just stuck that might work to break it free.
The odometer is hooked into the speed sensor, if the speedometer works then you know something in the cluster is bad. If neither the speedometer or odometer works then it could be the speed sensor or wiring as well.
Old Mar 19, 2016 | 08:57 AM
JDM_WHR's Avatar
Any idea on what to do about the coilovers ?
Old Mar 19, 2016 | 09:04 AM
cvcrcr99's Avatar
screwdriver and a hammer to loosen and tighten the sleeves or buy replacements
Old Mar 19, 2016 | 10:33 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Flat head and hammer*
Old Mar 27, 2016 | 03:56 AM
trm4life's Avatar
Well, first of all, the adjustment forks are available all over ebay. Don't get cheap ones though, they bend way too easily. If you use a hammer and a screw driver there's a good chance you'll damage the rings. With the sunroof, I'd try to run battery power to the motor. As it was mentioned youll have to take off the headliner. Don't rush it! The odometer should be mechanical, and run when the speedo cable spins. There's a chance someone may have screwed with it. Another dash cluster used on ebay is the way I would probably go to fix that. You could try to service it, see if the pieces were moved away from the gear that spins the numbers, but you may end up just making things worse. They are not easy to deal with trust me on that!
wwcrxww
Feb 13, 2012 03:17 PM
ZcivicC
Jul 29, 2009 08:54 PM
RTE117
Apr 22, 2009 09:52 AM
r0n3l
Mar 2, 2006 09:48 PM
S88HON
Oct 15, 2004 02:42 PM
