ej1 won't go past 4k rpms, but does once warmed up?
Old Mar 15, 2016 | 04:29 PM
betsy96's Avatar
Default ej1 won't go past 4k rpms, but does once warmed up?
Weird, it starts fine, I drive and once it hits 3-4k it splutters and won't go pass 4k, so I just shift before 3k. Once it warms up though it revs all the way up. Any ideas? D16z6 95 civic
Old Mar 15, 2016 | 05:27 PM
Txdragon's Avatar
Default Re: ej1 won't go past 4k rpms, but does once warmed up?
Bad coolant temp sensor?
Old Mar 15, 2016 | 06:28 PM
JarvisW's Avatar
Sol to Sol
Clean the FITV.
Its under the Throttle body and runs the Fast Idle till it warms up.
Old Mar 17, 2016 | 01:13 PM
betsy96's Avatar
Originally Posted by JarvisW
Clean the FITV.
Okay I'll do that tomorrow and check back
Old Mar 17, 2016 | 01:21 PM
Former User's Avatar
^Possibly, or the O2 sensor.
OP - Post all CEL codes.
Old Mar 17, 2016 | 10:30 PM
betsy96's Avatar
I don't have any check engine light on , and how can I tell if the coolant temp sensor is non functional?
Old Mar 17, 2016 | 10:32 PM
betsy96's Avatar
Clean the FITV.
I had another FITV from another z6 I had that was in better condition so I cleaned it and swaped it, no difference, still splutters around 3500k and won't go past 4k untill its warmed up.
Old Mar 17, 2016 | 11:02 PM
JarvisW's Avatar
Sol to Sol
K, follow Ron, he's really good at diagnosis.
Can you change O2s, or check it for spec at least.
Old Mar 18, 2016 | 05:15 AM
Does the CEL work?
Old Mar 18, 2016 | 01:27 PM
betsy96's Avatar
Does the CEL work?
Yea when I turn the key it turns on then off, it doesn't come on when I'm driving. I tried jumping it to pull the codes and all it does is have a solid check engine light , doesn't blink or anything just solid till I remove the paper clip.
Old Mar 18, 2016 | 01:55 PM
The next time the CEL turns on while driving, pull over and leave the engine running while you jump the service connector to pull the codes(s).
Old Mar 18, 2016 | 10:12 PM
betsy96's Avatar
Okay will do but it doesn't come on often, hardly ever .
Old Mar 18, 2016 | 10:19 PM
Be patient and ready.
Old Mar 19, 2016 | 09:08 AM
betsy96's Avatar
Also noticed that my fitv line that comes out bellow the throttle body is plugged and I looked up the diagram and its not suppose to be plugged. The intake Mani I'm using is from a d15b . I also have a z6 Mani I can use but what's weird about it the Mani's are almost the same besides one vaccume port on the back which hooks into a sensor that goes to the carcoal canister. So idk if I can use it and idk why I couldn't if the z6 Mani is for the z6 engine, maybe cause my ej1 is made in Canada? Idk if any of this makes a difference just thought I'd add it in. Noob here still learning.
Old Mar 19, 2016 | 09:45 AM
^Check the ignition timing with a timing gun. When was the last ignition system tune up?
Also post clear pictures of the IM, TB, IACV, and FITV.
Old Mar 19, 2016 | 11:57 AM
betsy96's Avatar
I will post pictures within the hour, and i haven't done a ignition system tune up , I swapped the motor in about a month ago got it from a friend who went b series, had low miles and everything was running on it so I didn't bother with it. When I bought the car it had a d15b in it which is why some parts I have swamped around. This was my first swap lol.
Old Mar 19, 2016 | 01:06 PM
betsy96's Avatar
Z6 Mani that was on the engine when I bought it
Old Mar 19, 2016 | 02:11 PM
LoveesHondas92's Avatar
My Dad had the same exact problem with his last week. All he had to do was: replace the bank one 02 sensor, change spark plugs, spark plug wires, and a new distributor. It sounds like a lot, but believe it or not his car ran like a brand new, lol.
Old Mar 20, 2016 | 09:32 PM
betsy96's Avatar
Bump
Old Mar 20, 2016 | 10:49 PM
eghatch9295's Avatar
Stancetard Hate Monger
when it bogs, try going WOT and see if it clears up. o2 sensors can go bad and cause similar symptoms, while not causing a code.
Old Mar 20, 2016 | 11:26 PM
fedoantie's Avatar
Old Mar 21, 2016 | 12:48 AM
betsy96's Avatar
Okay will try in the morning
Old Mar 21, 2016 | 07:05 AM
Do an ignition system tune up and check the ignition timing.
Connect the coolant hoses as intended:
Also install the D16Z6 IM and connect the vacuum hoses as intended:
The PCV hose connects to the unlabeled IM nipple.
Old Mar 21, 2016 | 06:06 PM
betsy96's Avatar
My z6 IM is plugd where the nipple should be in the back , idk why,also got a cell light it was 9 short blinks
Old Mar 21, 2016 | 06:13 PM
Code 9 fits with the problem. Ohm test the CYL sensor from the ECU connector.
