ccc drag wings
It's to help with rear end traction at higher speeds, aka stability as SPOOLINmatt said above.
The curves of a car create downforce on the front and lift on the rear. the faster you go, the stronger the forces. 150+ I believe is where it really starts to become noticeable, and 170+ it becomes borderline dangerous.
A rear spoiler is meant to create downforce at lower speeds (below 150), hence the actual angle to it, but it also creates some drag. at 150+ a spoiler hits it's stall point and causes more harm them good, creating less downforce, and stupid high amounts of drag. Twisted spoilers create almost as much downforce as a standard spoiler, but with much less drag, as it's twisted to work appropriately with the different airflow angles around and over the car.
A drag spoiler is flat[ish] because it is meant to create as little drag as possible, and not create a lot downforce, but just enough downforce to negate the lift created by the curve of the car, plus a hair more depending on adjustment.
they also help with proper chute deployment. incorrect airflow behind the car can cause catastrophic chute failure.
It helps regardless IMO. More stability is always better plus it helps aid in getting the turbulent air away from the rear of the car which creates drag on the car
granturismonut2
10
Sep 15, 2008 10:47 PM
BumbleBee Tuna
11
Jun 23, 2008 03:58 PM
Stryker908
33
Aug 18, 2004 11:35 AM
