Sputtering/Misfire at low RPMs
Old Mar 15, 2016 | 07:21 AM
Circaskaterr's Avatar
Default Sputtering/Misfire at low RPMs
I have a 1995 Civic with a D16Z6 engine it and and on the highway on my way home yesterday it started sputtering at low RPMs, below 3.2k, when I would give anything more than around 30-40% throttle. After the low RPMs it would rev out as normal without any sputtering. Within the last 500 miles I have replaced the following: Spark Plugs, Wires, Cap, Rotor, MAP, TPS, Fuel Filter, Gas Cap, and Fuel Pressure Regulator. I was guessing ignition coil but I wanted some second opinions. Any help would be appreciated.
Old Mar 15, 2016 | 02:13 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Sputtering/Misfire at low RPMs
My personal first step in that situation is a simple compression test.
Old Mar 15, 2016 | 02:18 PM
TechJohnson's Avatar
Check your compression. Clean the IACV and throttle. Check for vacuum leaks.
afnan
Jan 7, 2014 01:56 AM
bob95egdx
Jan 3, 2012 04:55 PM
soLaLive
Feb 15, 2010 04:35 PM
Rob.
Jul 15, 2009 01:26 PM
servion
Jun 25, 2002 04:01 PM
