Guy said he sold me ctr 5 bolt suspension but what is it really?????
Does anyone know what I was sold?
Will it fit my 97 Ek?
Is it crv rotor and calipers, pads?
It has abs sensor
I can't figure out what it is. He told me ek9 had smaller a rotors cali than integra type r but looks like that's not true :/
another thing is they look to be 32 mm axles used not 36mm
It has abs sensor
Why the hell would you ever buy anything if you didn't what it was, or if it would fit your car? WTF.
The EK9 had 11.1'' rotors up front.
yes
but crv I understand is same rotors calipers as jdm type r and 36mm axles
this is smaller calipers rotors and 32mm axles but 5 bolt.....
so then another Honda came with 5 bolt but small rotors and calipers?
all ctr= 32mm. us itr= 32mm. jdm itr= 36mm. all use 11.1" rotors. you got fucked.
edit: even the usdm crv is an 11.1" rotor. without digging too hard, the only US honda (not acura) i can find with a 10.2" front rotor AND 5 lug is the 03+ accord.
right
so what are these for?
will they fit my ek? exact swap in?
for around $70 us dollars each they are cheap and lighter than type r with bonus of the 5 bolt.
that's if they will work on an ek....
so to make it clear: 32mm axle size does NOT mean smaller rotors. what it DOES mean is an easier swap.
i seriously doubt those will fit your civic. post pics of the stampings on the calipers.
if you want 10" brakes for being "smaller and lighter", why not just grab them off any 96-00 civic ex?
I'm putting type r wheels on my ek. so needed 5 bolt
I'm not doing 24 hour road course racing at mosport so don't think I will be melting brakes on my 2200 pound cx lol. just putting some jdm type r wheels on my ek. not sure why members attack people instead of offering information.
stamping on caliper is ad57 23-14 2227
edit
these parts where shipped out of japan used
edit
Cool Cool Island Breezes. BOY-EE
Maybe the JDM CRV or some other JDM car has 5 lug rotors that are 10.2".
USDM CR-V spindles are a mix between CTR and ITR parts.
Here's an insane idea.
Try bolting them on.
I see S10 stamped on the knuckles which normally indicates a CR-V part. I don't get the small rotors though.
edit: either OP is trolling and is wondering if he can use the setup as is because he found it at the junkyard or he got trolled.
A little google search brought me to a discussion where someone really appeared to know their JDM CTR/ITR brake components.
JDM CTR appears to be 10.2" rotor with 32mm axles and 5 lug.
Thread found here:
NWP4LIFE - Honda Forum and Network: 5 Lug conversion
The poster who seems quite knowledgeable is Katman towards the end.
Thread found here:
Thread found here:
Thread found here:
yay me! with the gap between rotor and caliper bracket, it almost looks like someone put the wrong rotors on a crv knuckle.
But then it would be 36mm
So I went out and bought civic type r front spindles complete
Got back to shop. Bolted both on. One was messed up. I pulled rotor off and some guy in Japan restuded a 96 4 bolt to 5 bolt. So messed up I'm loosing my luv
Wat??
They're probably just CTR knuckles with Accord 5 lug rotors.
darkside's loreto
Northern California (Sales)
Mar 20, 2013 07:10 AM
neilscivic
Feb 24, 2010 08:01 AM
