Are A/C and Power Steering belts the same?
im looking to replace all my belts on my 1998 acura integra gs, and found this belt on ebay. are these two belts the same?
4PK875 4 Ribs A C Power Steering Poly V Serpentine Belt Assembly | eBay
as far as 4 rib yes but obviously there diffrent cause there going to be diffrent lengths just go to a parts store or call them and ask the part #'s Im using a B20 Crank pulley but it still should be the same as any other B series for the PS and i just got one at the autozone # 4PK920
Prolly cause the belt will be long enough for either the A.C or P.S but I just looked up the ps belt and indeed it's a 4pk920 and I had just a Lil room for tention so i think it's a snug fit but for ps it might be a bit short..
The lengths are just a bit different. Chances are you'll be adjusted to the end if you use the wrong belt, or even the other way around, be too tight and not be able to get it off/on. Don't get cheap belts, spend the 20-30 bux and get Gates, Continental, or another well know name brand.
