93 Del Sol Speedo help
Old Mar 14, 2016 | 10:46 AM
Bipolarcivic's Avatar
Default 93 Del Sol Speedo help
I have a 1993 Del Sol Si D16Z6 5Spd and the speedo isn't working with no codes however speeds above 70 the speedo starts to read 5 mph sometimes. First i replaced the VSS with one off my 94 Civic Coupe and still nothing. Next i checked the wiring connector as i know they tend to corrode and rust out. Checking with the key in the on position as follows, Yellow w/ Blue trace 12.17 V, Yellow 9.48 V and Black has a good ground. I unplugged the VSS drove around the block and only noticed that i had a CEL of 17 (VSS) and the odometer and trip wasn't working but everything else on the dash was. i'm out of ideals at the moment and thinking is it something in the trans?
Old Mar 19, 2016 | 08:31 AM
Default Re: 93 Del Sol Speedo help
Hello any one out there?
Old Mar 19, 2016 | 09:43 AM
Former User's Avatar
With the VSS connected, does the odometer or tripmeter work?
Old Mar 19, 2016 | 11:30 AM
yes, both work when the VSS is plugged in.
Old Mar 19, 2016 | 12:42 PM
mk378's Avatar
The problem must be in the speedometer head itself then, since both the speedometer and odometer use the exact same signal from the VSS. It may work to clean up and resolder its circuit board like you would a main relay. I've fixed a bunch of Toyotas that way.
Old Mar 19, 2016 | 01:03 PM
Old Mar 19, 2016 | 05:00 PM
ill check the cluster when i get time tomorrow and post my findings. the more i think about it, with it working sometime at 5 mph seems like a cold solider joint or a bad steeper motor but never had a speedo be this troublesome before in a honda. Thanks
Old Mar 22, 2016 | 04:19 AM
Update. I removed the cluster and didn't see any bad solider joints and checked voltage on the VSS wire in the connector in dash and its only reading 0.2 V but that not what it read on the same wire at the sensor. so im thinking that it might not be getting the signal all the way to the speedo. ill check back sat when im off and see what i can find.
Old Mar 22, 2016 | 05:26 AM
Run a new wire.
Old Mar 22, 2016 | 10:26 AM
mk378's Avatar
Did you take the speedometer unit out of the cluster, or just look at the printed wiring on the back of the cluster?
Odometer rolls and CEL does not light would almost always mean the sensor and wiring are OK.
Old Mar 22, 2016 | 10:29 AM
I don't believe that an open in the VSS-to-speedometer wire would throw code 17.
Old Mar 27, 2016 | 12:07 PM
yes, the circuit board looked ok no cold solider joints or loose connections. with the vss pluged up the odometer and trip work but no the speedo, however above 70mph+ sometimes it will read 5mph-ish. i planed on running a wire to see if that would work but my injectors stopped working so that is my main goal as its my daily driver. ill post what i find out when i can.
Old Mar 27, 2016 | 03:34 PM
Originally Posted by RonJ
Run a new wire.
Wait. If the odometer and tripmeter work, the wire is fine. Replace the speedometer unit.
Dripp_City
Oct 30, 2013 01:18 PM
delsoldriver96
10
Jul 31, 2013 09:38 AM
kaboom954
Feb 22, 2010 03:17 PM
dr_liver_bones
16
Dec 7, 2005 07:38 PM
