Someone revise my list?
Old Nov 6, 2002 | 08:32 PM
B20NOS's Avatar
Default Someone revise my list?
I just bought myself an 88 CRX HF...i am planning to do a B16 swap...and i want to buy all my parts before i go about swapping this...i want as LEAST of suprises while doing the swap as possible...I have my eyes on the Osaka jdm motors..it comes with:
1. Motor and tranny
2. Engine Wiring Harness
3. ECU
4. Distributor
5. Complete intake manifold and alternater
6. A/C
7. Power steering pump and all brackets and sensors
I realise i need additional parts. As of now, here's my list (pretty simple, I feel like i need more parts).
1. Subconverion harness (HASport)
2. HASport shift links
3. HASort motor mounts
4. 90-93 Integra Axles
5. A/C Bracket ( I want my A/C)
I know i need something else. If anyone has anyother opinoins about the parts i'm using, let me know!! Thanks for the info and advice...
Old Nov 6, 2002 | 08:38 PM
wronghand's Avatar
Default Re: Someone revise my list? (B20NOS)
Si or DX hubs. Those B-series axles don't like the HF hubs.
Old Nov 6, 2002 | 09:08 PM
r7's Avatar
r7
Default Re: Someone revise my list? (wronghand)
intermediate shaft? seals, gaskets, $
Old Nov 6, 2002 | 09:20 PM
Eggman's Avatar
Default .
http://hasport.com/Tech/Installs/Sho...0partslist.htm
- 90-93 rear mount bracket if your motor doesnt come with one
- 90-93 intermediate shaft if your motor comes without it or with a civic/crx one
Old Nov 6, 2002 | 11:23 PM
stockcrix1616's Avatar
Default Re: . (Eggman)
might wana change the timeing belt and water pump, just so you will know its fresh and wasnt damaged during shipping.
Old Nov 7, 2002 | 04:39 AM
Charlie Moua's Avatar
Default Re: . (stockcrix1616)
timing belt, water pump, valve cover gasket, all small PLASTIC hose/line, new spark plugs. Fresh oil, tranny fuiled(honda) raditator hose(top & bottom), more too.
I say plastic because i have found that plastic will become hard as a rock & non flexible after it's been sitting around for 10 years.
Old Nov 7, 2002 | 09:36 AM
JoshDM's Avatar
Default Re: . (Charlie)
don't forget thermostat
and some stuff you just might have to wait until the motor gets there. i know i'm not the only one that had a broken crank pulley, misc.sensors broken, exhaust manifold cut at the b-pipe
Old Nov 7, 2002 | 10:52 AM
irtep's Avatar
Default Re: . (JoshDM)
90-91 integra trottle cable
90-91 integra lower rad hose
92-93 gsr integra upper rad hose
Old Nov 7, 2002 | 10:56 AM
b16EF's Avatar
I didn't see it on anyones post but possibly the clutch disk, pressure plate, throwout bearing, pilot bearing and don't forget to have the flywheel machined.
Old Nov 7, 2002 | 11:21 AM
JoshDM's Avatar
Default Re: Someone revise my list? (b16EF)
oh yeah, 90' int. clutch cable
Old Nov 7, 2002 | 01:21 PM
irtep's Avatar
Default Re: Someone revise my list? (JoshDM)
stock clutch cable works too. i didn't change mine.
Abius
21
May 27, 2008 04:38 PM
TrU-HoNdA-HeAd
14
Apr 15, 2007 07:35 PM
dingusjt
Feb 11, 2003 07:57 AM
Skunk2 RaceR
Jun 1, 2001 05:12 AM
