pm8??
Old Nov 6, 2002 | 08:30 PM
BeEfiEBuNz's Avatar
Default pm8??
im almost done with my mpfi but i got a pm8 ecu? my friends tell me its from a 90-91 civic si? is this a good ecu for sohc zc? i got it from a junkyard so if its not the right one ill just get the 91 crx si ecu ;/ but it looks like the right one to me
Old Nov 6, 2002 | 08:37 PM
USDM 4G VTEC's Avatar
Default Re: pm8?? (BeEfiEBuNz)
no
SI one its PM6
the PM8 comes off the CRX HF if i am not mistaken.... it will run, but maybe too lean... that ecu was designed for fuel economy...and a very little engine that has no power...
wronghand's Avatar
The PM8 is out of an HF. You will need a PM6 which is out of the 88-91 Si.
Old Nov 6, 2002 | 10:36 PM
BeEfiEBuNz's Avatar
Default Re: pm8?? (wronghand)
so i will need to return my pm8 and get a pm6? what about a pm7? isnt that a ls ecu? which would be better? the 89 integ ls ecu or the 91 si ecu
Old Nov 6, 2002 | 10:43 PM
BeEfiEBuNz's Avatar
so how much of a difference is there for power between my pm8 and pm6 for my car?
Old Nov 7, 2002 | 11:54 AM
BeEfiEBuNz's Avatar
okay i xchanged the pm8 for a 89 civic si ecu??? pm5 it says? will this work?
Old Nov 7, 2002 | 12:43 PM
BeEfiEBuNz's Avatar
eh? anybody? ttt
Old Nov 7, 2002 | 01:46 PM
BeEfiEBuNz's Avatar
ok so i guess pm5 is same ecu i first had -_- now i got 2 ecus i dont need! ARGH... well im gonna go back and bitch.. i want a pm6 or pg7 right? pg7 isnt a 89 integ 5 speed?
Old Nov 7, 2002 | 01:50 PM
wronghand's Avatar
The PM5 is out of a Civic/CRX DX. This won't even work with the mpfi. You need either a PM6 or the PG7. Be careful with the PG7. It will have to be from a 88 or 89. The 86 and 87 are different and won't work. Also make sure you get one from a 5 speed if you go that route.
Old Nov 7, 2002 | 04:32 PM
BeEfiEBuNz's Avatar
hehe got my pm6 now i think off a 88 si
davidcrx89
Mar 1, 2005 08:27 PM
Project_ED8
Sep 13, 2003 08:21 PM
Hondasaurs
Mar 19, 2002 03:38 PM
89hondarex
Jan 29, 2002 05:54 PM
