water pump failure
Old Mar 12, 2016 | 11:21 AM
Rick1t's Avatar
Default water pump failure
Question.........Can a water pump fail....or do they just leak? I don't mean seize up....that would be a failure for sure......Without going into all of the details...... I believe I have a bubble in my system of maybe my water pump isn't doing its job....it only had a 15K miles on it.
In the last couple of months I've put in a new radiator, head gasket and about 15K ago did the timing belt and water pump. Everything has been good until the weather broke....temps in the +60 the old girl has been running hot.........I'm not losing fluid......just hot. I did the bubble deal and all without success.
I'm thing of taking her to radiator place and have them do a flush........I must admit I did try some of the chemical head gasket treatment.......that was before the new radiator........so it should be clear of ****....but not so sure about the water pump, heatercore or the block.........
Thoughts?
Thanks in advance
Rick
Old Mar 12, 2016 | 12:30 PM
tony_2018's Avatar
Fish Twig
Default Re: water pump failure
You've been here long enough to know what is needed in a tech thread.
Yes a water pump can fail
Old Mar 12, 2016 | 01:17 PM
Rick1t's Avatar
Tony
Thanks for the reply.........maybe I'm slow...... What did I do that was incorrect? I don't have a clue what you mean....
Rick
Old Mar 12, 2016 | 01:27 PM
mk378's Avatar
Post car details: year, trim, whether engine is stock type or swapped (and if so, with what).
Old Mar 14, 2016 | 12:05 PM
Rick1t's Avatar
Ah.....sorry. Since I posted on this forum.........but I understand....
98 Civic Ex
stock 385K miles
I did the timing belt/waterpump 15K ago. Radiator 5K ago....I did not do a flush....which I should have.......because I used several chemical products to try to seal the head gasket what a mistake.......
I do not see circulation at the radiator cap when the engine is running......so I have to assume the Waterpump is toast........is there any other way to confirm this?
I will put an OEM pump as the replacement.....
Thanks
Rick
Old Mar 14, 2016 | 01:30 PM
tony_2018's Avatar
Fish Twig
you fucked up.
95DC2GS-R
Aug 12, 2009 05:23 AM
Mr_Moos
Jun 24, 2007 10:04 PM
cadougherty_67
Mar 29, 2005 06:21 PM
Mrob91GS
Mar 26, 2005 08:25 AM
B18PoweredCivic
Jul 25, 2003 01:37 PM
