Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
r18a1 starter rebuild kit?
Old Mar 10, 2016 | 08:36 PM
raverx3m's Avatar
Default r18a1 starter rebuild kit?
anyone know if theres a starter rebuild kit available like for b series?
the starter is worn out but I always just replace the solenoid contacts and the plunger and it keeps working on my b series
was wondering whats the cheapest route to fix worn out starter on this motor
Old Mar 11, 2016 | 12:00 PM
holmesnmanny's Avatar
Default Re: r18a1 starter rebuild kit?
Only if it's a Denso. Mistubas aren't really rebuildable.
google larry b's starter contacts and call him up, the kits are only like $20 and it's about 30 minutes to rebuild
Old Mar 26, 2016 | 11:25 PM
raverx3m's Avatar
mitsuba is rebuildable since it has a different issue.
mitsuba doesn't have a plunger
but the motor brushes wear out.
Honda offers a complete brush assembly for 50 bucks or ebay for 19 bucks non oem
or just buy brushes if you have a spark welder and weld new ones on it for less than 10 bucks.
Old Mar 27, 2016 | 07:04 AM
foumer's Avatar
W95 gives me a hard-on
I just ordered a kit from ebay for $24 for the Mitsuba. I will post pics once I rebuild mine.
Old Mar 28, 2016 | 02:11 AM
Why did you ask a question you already had the answer to ?
Old Mar 28, 2016 | 08:35 AM
raverx3m's Avatar
Obviously i didnt lol
Why else would i ask
Old Apr 5, 2016 | 04:25 AM
foumer's Avatar
I just got around to rebuild the starter. It was pretty easy. I didnt take pictures because I was in a hurry. The brushes were worn out, one of them was actually missing but the motor had no damage so I just sanded it a tiny bit with a 220 grit paper where the brushes make contact to take the roughness out of it. Grease up the gears and bearings inside.
Just make sure you test it before putting in back on the car because its PITA to take it back out. Hopefully it lasts quite a while since the new brush set its made in china
This is the kit I got
Mitsuba Starter Brush Repair Kit Accord Civic CRV TSX RDX | eBay
Old Apr 8, 2016 | 09:36 PM
raverx3m's Avatar
replaced the worn out parts cleaned greased up
tested out of the car turns good just like normal starter
put it back in with a lot of bitching
barely ****** turns.
brand new battery
before the plunger wouldn't click all the way and wont crank.
not it cranks but very slow and after few tries it just stops turning completely but plunger still clicks good( since its brand new)
Old Apr 14, 2016 | 09:58 AM
foumer's Avatar
damn I guess you are gonna have to get a rebuilt one
Old Apr 14, 2016 | 03:38 PM
raverx3m's Avatar
Lol i guess i should press the brush springs in
would be good to know that im supposed to snap the springs in place to release the brushes
Old Apr 15, 2016 | 07:18 AM
foumer's Avatar
Oh sh^t, you forgot that..lol.. I almost made the same mistake. I was messing with the new brushes and pushed one of the springs in by mistake and then I realized they all had to put pushed in once the motor was put in place..
Old Apr 15, 2016 | 09:14 AM
raverx3m's Avatar
Well im really good at removing that starter now lol
Old May 1, 2016 | 03:09 PM
gabrielhermank's Avatar
I bought a used starter from local salvage yard for $100.
Dekorum
Oct 8, 2013 01:50 PM
Importracer_001
Sep 6, 2009 04:49 PM
liquid51
Jul 1, 2003 08:18 AM
