D16Y7 into 93 delsol (OBD2 Engine with OBD1 Harness and ECU)
Posting this again cause I didnt get any help.
Engine is in it but idk which plugs and clips I need to put on the OBD1 harness and which vacum lines I need to close.
I have a d16zc harness in the car now and a p2e harness on the side.
Can I just use the p2e harness? I noticed it doesnt have the same connector as the dash though so could I even start it?
Im new at this SOMEONE TELL ME WHAT I SHOULD DO!
What kind of IM you had before... the Y7 is not good at all... look for a Z6/B7/Y8 IM and will be almost plug and play.... and no need to close vacuum lines...
But I also have a y7 lying around.
I read they suck but at this point I just want to get it running then when I get paid im picking up a z6.
But is it possible to use a zc on this y7?
Or should I just throw the y7 on in order to get it running?
I read with the z6 you need to close a line on the manifold
Custom work just causes more problems, thats all I can tell you.
Not sure why you would ask if it would work when you stated you have the zc manifold on the y7.
Do you have everything else from the manifold installed as well or are you running a couple of y7 components on the zc manifold? What ecu? What is the issue? No you cannot use the p2e harness because the car is obd1 and is different.
dokdok
Mar 4, 2012 04:02 PM
