00 civic w/ OBD2a D6y7 engine harness and d16y8 swap - no power to fuel pump
Old Mar 7, 2016 | 05:15 AM
unrivaled's Avatar
Default 00 civic w/ OBD2a D6y7 engine harness and d16y8 swap - no power to fuel pump
Hello ht, ok so I just picked up a non running 00 civic hatchback and previous owner swapped in a d16y8. The engine harness is a obd2a non vtec harness, the ecu Is a p2e. On the ecu side you have the 3 ecu plugs and green plug plus one additional connector that was originally for the 2000 chassis...now with the above setup which is the correct way to get this to work...as of now there is no power going to the fuel pump unless I ground terminal 8 on the main relay, before I start to tracing wires I need to know what to do with the extra plug.
Old Mar 7, 2016 | 06:17 AM
Former User's Avatar
Default re: 00 civic w/ OBD2a D6y7 engine harness and d16y8 swap - no power to fuel pump
Start here ---> Buy an OBD2b D16Y8 engine harness and an OBD2b P2P ECU.
Old Mar 7, 2016 | 07:17 AM
unrivaled's Avatar
Default Re: 00 civic w/ OBD2a D6y7 engine harness and d16y8 swap - no power to fuel pump
That's what I was not hoping to do, but to simply everything it's the easiest path. I got the car to start by grounding terminal 8 but then noticed my tach wasn't working and a few other things. Well thanks for clearing that up for me. Time to search the forums.
Old Mar 7, 2016 | 03:54 PM
tony_2018's Avatar
Fish Twig
Wrong engine harness, find an obd2B. You see that "B" at the end? Yeah, get that. Not the "A", a "B". THAN get an obd2b to obd2a conversion harness. If you don't want to get the harness than find an obd2b ecu. That simple.
You wanna not spend money? Than prepare to be adventurous. You need to depin all the wires and match it up to the ecu. Yeah, super fun. GL with your decision.
And if you still can't make a decision on which path to go just take it to a shop.
Old Mar 7, 2016 | 07:57 PM
unrivaled's Avatar
I ended up finding a local here and I bought the obd2b harness for 50 bucks. Then he took me to go look at the donor car and bought 2 door panels, ignition switch assembly, core support, p2p ecu, both fenders and front bumper for 100 dollars more...scored big time. Thanks everyone
devoncll1
Mar 10, 2017 11:21 AM
Ottombille
19
Aug 7, 2016 07:37 PM
guedo148
Jun 14, 2007 11:12 AM
Eaglekper0046
Sep 27, 2005 09:41 AM
goat442003
Jun 21, 2003 07:16 PM
