93 accord auto Trans ?
Anything from 90-02 - F22A*, F22B* & F23A* will physically bolt up. only difference is when the connectors may have changed. Even then it's just a matter of cutting and soldering a few wires to the connectors that work for the VSS/Trans.
Not sure how involved you want to get. Plug and play, 95 is the last year for OBD1.
POINT OF ORDER!
90-97 Accords used the H4A transmission. OBDII on 96/97 does not affect the transmission as a unit itself, still same sensors and shift solenoids.
92-96 Preludes and 95-97 F22 Odyssey vans also used the H4A.
Biggest differences is the
98-02 Accords used the M6HA transmission. This is a different bugger of a trans. This trans can physically bolt up but is quite a bit different from a controls stand point from the earlier H4A and cannot be used in the earlier cars.
warchild077
Apr 24, 2012 08:12 AM
arcadiagreen
Mar 27, 2012 06:29 PM
DisOnesAPlaya
Feb 3, 2010 08:09 PM
autoraceparts.com
May 1, 2007 02:53 PM
