Civic hesitates upon first acceleration only, p0300 p0301, p0302, p0303, p0304
Old Mar 5, 2016 | 03:46 AM
drewbru's Avatar
Default Civic hesitates upon first acceleration only, p0300 p0301, p0302, p0303, p0304
98 civic DX D16Y7
The first time you accelerate after the car has been sitting for a few hours, it hesitates until you stomp on it to get the rpms up and then it's ok after that. I'm getting the codes p0300 p0301, p0302, p0303, p0304
History: It was doing this months ago and I just lived with it. Then I started having idle surging problems. I don't recall having the hesitation problem during that period of time. After I replaced the IAC, the surging issue went away but the hesitation has come back.
I have replaced the plugs, dist cap and rotor, and the wires look great.
I don't want to throw more parts at it until I have a better idea of what it could be. Any idea how to narrow this down?
Thanks
Old Mar 5, 2016 | 06:09 AM
tony_2018's Avatar
Fish Twig
Default Re: Civic hesitates upon first acceleration only, p0300 p0301, p0302, p0303, p0304
Dude....look up the CEL codes and tell us what they mean....
Old Mar 5, 2016 | 07:23 AM
NotARaCist's Avatar
I never narc'd on nobody!
"Look great" is diagnostically worthless. When were they last replaced? Did you use an OEM cap and rotor, or parts store trash? Did you get proper NGK plugs, or "Champion" ****?
Old Mar 5, 2016 | 02:25 PM
drewbru's Avatar
I've had the car 1.5 years and the wires were on when I bought it. They look like they were replaced shortly before I got it. No visible damage on the exterior and I don't see any arcs when it is running in the dark. The dist. cap and rotor are Bosch and the plugs NGK.
I changed the fuel filter today so I'll be able to see if that did anything after it sits tonight.
Old Mar 5, 2016 | 02:30 PM
eghatch9295's Avatar
Stancetard Hate Monger
it wont. multiple misfire= **** distributor or mechanical timing off. fuel isn't going to help anything.
Old Mar 5, 2016 | 02:44 PM
NotARaCist's Avatar
What color is your spark? Do a compression test, and give us the numbers.
Old Apr 11, 2016 | 04:28 PM
drewbru's Avatar
I took the car into my mechanic. He did a compression test on 2 of the cylinders and they were ok. The spark plugs in the other two were too tight and he didn't remove them for fear of snapping them. So that doesn't tell me much.
He said the most likely problem was the distributor. I replaced it with one from Amazon that I'm sure isn't the best but good enough.
That didn't fix the problem either.
I've never messed with timing. Is it possible for it to be off for the first few minutes and then resolve itself?
Old Apr 11, 2016 | 05:12 PM
Former User's Avatar
If you reset the ECU, do all the codes return?
Get those stuck plugs out and replace all of them.
Also replace the plug wires and the fuel filter.
Old Apr 12, 2016 | 08:34 AM
drewbru's Avatar
Within the last 15,000 miles, I've replaced the spark plugs, plug wires, air filter, fuel filter, distributor cap and rotor, and then the distributor. Obviously non of that has fixed it.
When I was describing the issues with the car to my mechanic, I remembered another issue that the car has that I didn't think was related. It slowly loses coolant and I can't find the source of the leak. I was wondering if this could be leaking into the cylinders when it is not running and causing the issue. There isn't any signs of coolant in the oil or oil in the coolant. I also have not noticed any unusual smoke from the exhaust.
Old Apr 12, 2016 | 09:08 AM
Pressure test the cooling system, and rent a block tester kit from AutoZone.
Old Apr 16, 2016 | 04:09 AM
drewbru's Avatar
I rented a pressure test kit for the cooling system. I pressurized up to 16 lbs. It lost about 1 lb / 10 min. I looked everywhere and couldn't find the leak. Possibly the cap didn't fit exactly? I doubt it.
I depressurized it but left it on and started the car. The car eventually came up to 15 lbs and held there. I thought that would signify that the head is ok. But if it is, I still have no idea where the coolant is going or why it's running like this.
Old Apr 16, 2016 | 07:39 AM
Old Apr 16, 2016 | 02:01 PM
drewbru's Avatar
I found a block tester at AutoZone like you (RonJ) suggested. I tried Pep Boys and Advanced Auto first because they were closer and neither one loaned that block tester.
I used it today and it doesn't appear to have any exhaust leaks into the cooling system.
The codes do come back after they are cleared.
I'll work on the stuck plugs next.
What are the chances of it being an issue with the crank shaft position sensor?
Thanks for your suggestions.
Old Apr 20, 2016 | 10:07 AM
drewbru's Avatar
I had it checked out by a second mechanic who diagnosed it with a head gasket leak. That's beyond my skills and available time to repair. They want a couple grand for the whole job. With almost 200K, that's not going to happen.
I think that I'll try the Blue Devil Head Gasket Sealant and see if it helps at all.
Old Apr 20, 2016 | 12:43 PM
Don't. Do it right or don't do it at all.
Old May 21, 2016 | 10:01 AM
drewbru's Avatar
I am not going to spend the money on this car to fix the head so I tried the Blue Devil Pour-N-Go. It seems to have drastically slowed down the coolant loss and the car has more power. It also was running fine even at startup. However, it is running poorly at startup again but I don't think it is loosing coolant from the head. There is a little loss from the water pump.
What else could it be? ECU?
spanishstud
Mar 1, 2015 08:03 PM
jebickers
Apr 11, 2011 09:31 PM
mainecivic
Sep 17, 2010 01:04 PM
zanglezonker
Dec 9, 2008 04:17 AM
95TEG
Dec 7, 2006 09:09 AM
