92 Civic VX high idle only with headlights on.
Old Mar 3, 2016 | 02:18 PM
codizz88's Avatar
Default 92 Civic VX high idle only with headlights on.
my vx idles fine nice and low until i turn on the lights and it usually idles around a 1000. I know they go into a compensated idle when the engine has a load but jumping up to 1000 is definitely too high, curious if this could be adjusted or is something faulty? thanks.
Old Mar 3, 2016 | 03:12 PM
Former User's Avatar
Default Re: 92 Civic VX high idle only with headlights on.
Adjust the idle speed. See FAQs sticky.
Old Mar 3, 2016 | 03:31 PM
codizz88's Avatar
adjust the idle even though it idles nice and low like a vx should when lights arent on?
Old Mar 3, 2016 | 03:38 PM
NotARaCist's Avatar
I never narc'd on nobody!
"Nice and low" diagnostically means nothing. Get an external tach, and see exactly what your car is idling at. Specifics.
Old Mar 3, 2016 | 03:44 PM
codizz88's Avatar
Nice and low as in low like a d15z1 is supposed to be. if its idling around 500-600 which is normal then jumps to 1000 with headlights on i figured it would be something other then adjusting idle speed itself otherwise i would have just went through the procedure to adjust it. Not sure if there was a voltage regulator or something alternator related that senses current to tell engine to pickup rpms to compensate.
Old Mar 3, 2016 | 03:56 PM
NotARaCist's Avatar
You aren't listening to what either of us are telling you. It's a well known fact that the OEM tach, if you even have one, is horribly inaccurate. Get an external tach. Find out what your idle speed is. You might be idling too low, which could cause exactly the symptoms you're having. Do I need to spell it out more clearly for you, or are you going to listen to advice given now?
Old Mar 3, 2016 | 04:20 PM
codizz88's Avatar
Except that i have, even though what was said is very little to begin with. Regardless if the ******* tach is off a little i have been around enough vehicles, motorcycles anything else with an engine to know around what rpm its at, and if the rpms damn near double instead of increasing around 100 or so for compensated idle then that is what led me to believe the possibility of it being something else...
If where your getting at is that if the idle is too low, then with a load on the engine it somehow idles higher than normal then i dont see how it was so hard to say that in the first place.
Last edited by Former User; Mar 3, 2016 at 04:24 PM. Reason: Insulting remarks deleted
Old Mar 3, 2016 | 04:21 PM
Yeah, you really need to hook up a proper tach and post the redings Sometimes the cluster tach is just a decoration with regard to accuracy.
Originally Posted by codizz88
If where your getting at is that if the idle is too low, then with a load on the engine it somehow idles higher than normal then i dont see how it was so hard to say that in the first place...
Please keep the discussion civil and focused on tech.
Old Mar 3, 2016 | 04:28 PM
codizz88's Avatar
Tell that to the other guy, where the confrontation started. Start at the source, nothing civil about what he said.
Old Mar 3, 2016 | 04:32 PM
He asked a reasonable question, and you followed with an insult. Please get your thread back on track by refocusing the discussion on tech.
Old Mar 3, 2016 | 04:37 PM
codizz88's Avatar
No he started with an insult then i followed...are u seriously going to turn a blind eye to how this started in the first place? Thats fine close the thread im done.
live4soccer7
13
Oct 12, 2022 02:38 AM
Jimi Hondrix
11
Apr 19, 2016 03:44 PM
jlk16188
Sep 14, 2013 12:45 PM
Phoenix.
Feb 10, 2013 11:53 PM
clutcher
Apr 6, 2005 08:04 PM
